smis crsp
La smis crsp El comando describe los subperfiles registrados en CIM admitidos por el proveedor SMI-S de NetApp, incluidos los subperfiles de proveedores SMI-S de NetApp.
Sintaxis
smis crsp
[-t {http | https}]
Ubicación
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Nivel de privilegio
Un usuario con un nombre de usuario y una contraseña válidos
Parámetros
[-t {http | https}]Protocolo que se utilizará: HTTPS (predeterminado) o HTTP
Ejemplo
La smis crsp comando y su salida abreviada:
smis crsp PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.4.0" PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.5.0" PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.6.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.4.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.5.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.6.0" PG_RegisteredSubProfile.InstanceID="SNIA:Object Manager Adapter:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:iSCSI Target Ports:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:iSCSI Target Ports:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Software:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Multiple Computer System:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Access Points:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Target Port:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Masking and Mapping:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Masking and Mapping:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Server Performance:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Server Performance:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Physical Package:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Physical Package:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Health:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FileSystem:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Storage:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export Manipulation:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File System Manipulation:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Filesystem Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Server Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FileSystem Quotas:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Job Control:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Job Control:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Location:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:NAS Network Port:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Replication Services:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Replication Services:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Capacity Utilization:1.4.0"
