affichage de configuration smis
Le smis config show Commande répertorie les informations de configuration actuelles du serveur CIM.
Syntaxe
smis config show
Emplacement
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Niveau de privilège
Administrateur (Windows)
Exemple
Le smis config show et son résultat :
smis config show slp: Current value: true tracelevel: Current value: 4 traceComponents: Current value: XmlIO,Thread, IndicationGeneration, DiscardedData, CMPIProvider, LogMessages, ProviderManager, SSL, Authentication, Authorization traceFilePath: Current value: traces/cimserver.trc enableAuditLog: Current value: true logLevel: Current value: WARNING sslKeyFilePath: Current value: cimom.key sslCertificateFilePath: Current value: cimom.cert passwordFilePath: Current value: cimserver.passwd enableHttpConnection: Current value: true enableHttpsConnection: Current value: true httpPort: Current value: 5988 httpsPort: Current value: 5989 enableAuthentication: Current value: true
