Delete an app for a managed cluster
Collaboratori
DELETE /accounts/{account_id}/topology/v2/managedClusters/{managedCluster_id}/apps/{app_id}
Removes the specified App API resource.
Side Effects
  • Billing stops.
  • If the application is still running on a cluster, the application is no longer considered to be under management and will no longer show up under /apps, but it will still show up under /apps.
  • If the application is not running on a cluster, the application is no longer known to the system and will no longer show up under /apps.
  • All associated snapshots, backups, and the stored application state are removed.
account_id
string
path
True
  • example: {{.Account}}
managedCluster_id
string
path
True
ID of the containing managedCluster resource
app_id
string
path
True
ID of the app collection to list
Status: 204, Indicates if the app resource was deleted.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
invalidParams
name
string
True
reason
string
True
