List all certificates
Collaboratori
GET /accounts/{account_id}/core/v1/certificates
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
continue
query
False
Indicates the token to resume listing from.
URL examples: "continue="
OpenAPI examples: ""</continue>
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
  • example: certUse%20eq%20'rootCA'
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,cn,isSelfSigned
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
orderBy
string
query
False
Indicates the sort order of resource when listing a collection.
URL examples: "orderBy=name", "orderBy=name%20desc"
OpenAPI examples: "name desc"
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: certificate_1.0_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-certificates",
  "version": "1.0",
  "items": [
      "f97f3441-075e-4f9b-9d1e-47f9f62a3fc4",
      "prod.region-1.example.com",
      "true"
      "5e365b4d-034f-4f13-95ef-d3a7fbc0df3d",
      "prod.region-2.example.com",
      "false"
      "11ceb350-1999-4b79-80a6-46a980a27856",
      "prod.example.com",
      "false"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_stateTransitions
from
string
True
to
array[string]
True
type_astra_stateDetails
type
string
True
title
string
True
detail
string
True
type_astra_label
name
string
True
value
string
True
type_astra_metadata_update
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
type
string
True
  • "application/astra-certificate"
version
string
True
  • "1.0"
id
string
True
certUse
string
True
JSON string indicating the use of the certificate. If not specified, defaults to "rootCA". Defined values are:
  • "rootCA" - The certificate is a certificate authority (CA) certificate used to trust any certificate signed by that CA.
  • "intermediateCA" - The certificate is an intermediate CA certificate issued by a root CA.
cert
string
True
JSON string containing a Base64 encoded PKCS-11 formatted certificate (PEM). Defined values are:
  • Conforms to the base64 Encoded Data Schema
cn
string
True
JSON string containing a common name extracted from the certificate. Defined values are:
  • Minimum length: 1
  • Maximum length: 511
expiryTimestamp
string
True
JSON string containing a timestamp indicating when the certificate expires. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
isSelfSigned
string
True
JSON string indicating whether the certificate is self-signed. If not provided on create, the value defaults to "false". On update:
  • If the value is provided, that value will be used.
  • If the value is not provided and the "cert" field is included in the update, the value will be set to "false".
  • If the value is not provided and the "cert" field is not included in the update, the existing value will be retained. Defined values are:
  • "true" - The certificate is self-signed.
  • "false" - The certificate is not self-signed.
trustState
string
True
JSON string containing one of a set of enumerated values indicating whether the certificate is trusted. Defined values are:
  • "untrusted" - The certificate is not trusted.
  • "trusted" - The certificate is marked as trusted.
  • "expired" - The certificate is expired, so is neither trusted or not trusted.
trustStateTransitions
array[type_astra_stateTransitions]
True
JSON array of JSON objects, each representing the set of permitted state transitions from a given defined state. Each JSON object contains the fields "from" and "to", where the "from" value is the name of a state, and the "to" value is an array of permitted destination states.
trustStateDesired
string
False
JSON string containing a value indicating whether the certificate is trusted. If not specified on create, the default value is "trusted". Defined values are:
trustStateDetails
array[type_astra_stateDetails]
True
JSON array of JSON objects that lists additional details about the trust state of the certificate. If no details are available, this array will be empty.
  • Minimum Items: 0
metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
