Retrieve a group
Collaboratori
GET /accounts/{account_id}/core/v1/groups/{group_id}
Returns the stored Group API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
group_id
string
path
True
ID of the group collection to list
Status: 200, Returns the stored Group API resource in the JSON response body.
type
string
True
  • "application/astra-group"
version
string
True
  • "1.0"
id
string
True
name
string
True
The name of the group resource. If not specified on create, the value will be set to
  • first Common Name (CN) Relative Distinguished Names (RDN) if found in the authID,
  • authID, otherwise. if not specified on update, the value will be preserved without modification. Defined values are:
  • Minimum length: 1
  • Maximum length: 256
authProvider
string
True
The authentication provider for the group resource. Defined values are:
  • "ldap"
authID
string
True
The Distinguished Name (DN) for an LDAP group. Defined values are:
  • Minimum length: 1
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-group",
  "version": "1.0",
  "id": "d8560bb2-7c87-5331-a78d-4e870b22e9a9",
  "name": "engineering-group",
  "authProvider": "ldap",
  "authID": "CN=Engineering,CN=groups,DC=example,DC=com",
  "metadata": {
    "labels": [],
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/12",
  "title": "Invalid headers",
  "detail": "The request headers are invalid.",
  "status": "400"
Status: 500, Internal server error
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/34",
  "title": "Internal server error",
  "detail": "The server was unable to process this request.",
  "status": "500"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
