List all notifications
Collaboratori
GET /accounts/{account_id}/core/v1/notifications
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,summary
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
  • example: 4
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
orderBy
string
query
False
Indicates the sort order of resource when listing a collection.
URL examples: "orderBy=name", "orderBy=name%20desc"
OpenAPI examples: "name desc"
skip
string
query
False
Indicates the number of resources to skip over when listing a collection.
URL examples: "skip=1"
OpenAPI examples: "1"
count
string
query
False
Indicates if the total number of resources should be returned in the metadata object.
URL examples: "count=true"
OpenAPI examples: "true"
  • example: true
continue
query
False
Indicates the token to resume listing from.
URL examples: "continue="
OpenAPI examples: ""</continue>
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: notification_1.3_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-notifications",
  "version": "1.3",
  "items": [
      "4f8273ee-883d-47f0-a512-9e27b6285f20",
      "Discovering Applications in Cluster"
      "1cdd26dc-5eb0-4cf4-a0c1-39a9b83720e1",
      "Application Discovered"
      "275a8c6f-ebf6-4d10-b671-77d1b8c7c0a6",
      "Application Discovery Failed"
      "4325f971-ca9c-4a52-bc9a-da6ec62e6bfe",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
data
JSON object containing additional event-specific information.
ttl
number
False
JSON number indicating the number of seconds (since the eventTime) that the event will be retained. This field is only included when an event is automatically deleted after the specified number of seconds. When deleted, if the event has a notification destination, all associated notifications are also deleted. When deleted, if the event has a banner destination, the banner is also removed. The absence of this field (or a value of "0") means that an event will not be automatically deleted.
isAcknowledgeable
string
False
JSON string indicating whether the banner is dismissible. Defined values are:
  • "true" - The banner is dismissible
  • "false" - The banner is not dismissible
type_astra_label
name
string
True
value
string
True
type_astra_metadata
  • Conforms to the Astra Metadata Schema
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
  • "application/astra-notification"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
  • "1.3"
id
string
True
name
string
True
JSON string containing a dot notation (.) hierarchical name for the event. Defined values are:
  • Minimum length: 3
  • Maximum length: 127
  • Defined regex is: "^[a-z])(\.([a-z])+$"
sequenceCount
number
True
JSON number containing a sequence count. The number is incremented by the system each time a new event is received.
summary
string
True
JSON string containing the short-form (less than 40 characters) summary of the event. Defined values are:
  • Minimum length: 3
  • Maximum length: 79
eventTime
string
True
JSON string containing a timestamp that indicates when an event occurred. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
source
string
True
JSON string containing the lowercase name of the service generating an event. Defined values are:
  • Minimum length: 1
  • Maximum length: 19
  • Defined regex is: "^([a-z-])*$"
resourceID
string
True
JSON string containing the resource ID associated with an event. Defined values are:
  • Conforms to the Astra Identifier Schema
additionalResourceIDs
array[string]
True
JSON array of JSON strings, each containing a resource ID of an additional resource associated with the event. While the "resourceID" field contains the primary resource associated with this event, this field contains any number of additional resource IDs to be associated with the same events. If no additional resources are associated with the event, the array will be empty. Defined values are:
resourceType
string
True
JSON string containing the media type of the resource associated with an event. Defined values are:
  • Minimum length: 4
  • Defined regex is: "^application\/astra-([a-zA-Z])+$"
correlationID
string
True
JSON string containing a UUIDv4 correlation ID that allows related events to be grouped together. Defined values are:
severity
string
True
JSON string containing one of the following values that indicate the severity of an event. Defined values are:
  • "cleared" - Indicates that a previously reported event describing a condition is no longer active. An event with severity "cleared" will use the same summary and correlation ID to allow it to be matched up.
  • "indeterminate" - Indicates that the severity cannot be determined.
  • "informational" - Indicates a change in state that is both expected and normal (not defined in X.733).
  • "warning" - Indicates the detection of a potential or impending service affecting fault, before any significant effects have been felt.
  • "critical" - Indicates that a service affecting condition has occurred and immediate corrective action is required. Definitions for "cleared", "indeterminate", "warning" and "critical" are based on definitions in clause 8.1.2.3 of CCITT X.733.
class
string
True
JSON string containing one of the following values that indicate the class of the event. Defined values are:
  • "system" - The event is related to an internal event or request.
  • "user" - The event is related to a user-initiated event or request.
  • "security" - The event is related to a security issue.
description
string
True
JSON string containing a long-form descriptive text about the event. Defined values are:
  • Minimum length: 3
  • Maximum length: 1023
descriptionURL
string
False
JSON string containing the URL that enables and links a button in the banner to external documentation. Defined values are:
  • Minimum length: 3
  • Maximum length: 4095
correctiveAction
string
False
JSON string containing a long-form descriptive text about what corrective action should be taken in response to the event. Defined values are:
  • Minimum length: 3
correctiveActionURL
string
False
JSON string containing the URL that links a button in the banner to a page within the UI to fix the issue. Defined values are:
  • Minimum length: 3
visibility
array[string]
False
JSON array of JSON strings, each indicating an RBAC role permitted to view the event. Roles are OR-defined together. Optional. If omitted, a user with any RBAC role can view the event. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
destinations
array[string]
False
JSON array of JSON strings, each indicating an additional destination for the event. These allow a service to provide hints about where an event must be routed in addition to the Activity service's activity log. Optional. Defined values are:
  • "notification" - The event is marked as a notification, and will be accessible through the notifications API endpoint.
  • "banner" - The event is marked as a banner.
  • "support" - The event is marked as a support-related event.
resourceURI
string
False
JSON string containing the URI associated with the event. Only included for events related to API operations. Defined values are:
  • Minimum length: 3
resourceCollectionURL
array[string]
False
JSON array of JSON strings, each indicating the fully-expanded access URL of the resource associated with the event. Defined values are:
  • Minimum length: 1
resourceMethod
string
False
JSON string containing the HTTP method invoked. Included only for events related to API operations. Defined values are:
  • "options" - OPTIONS API operation
  • "post" - POST API operation
  • "get" - GET API operation
  • "put" - PUT API operation
  • "delete" - DELETE API operation
resourceMethodResult
string
False
JSON string containing the result of the HTTP method invoked. Only included for events related to the API operations. Defined values are:
  • Defined regex is: "^[1-5][0-9]{2}$"
userID
string
False
JSON string containing the user ID associated with an event. Only included for events associated with the user-initiated actions. Defined values are:
accountID
string
False
JSON string containing the account ID associated with an event. Only included for events associated with an account. Defined values are:
data
data
False
metadata
type_astra_metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
