Retrieve a subscription
Collaboratori
GET /accounts/{account_id}/core/v1/subscriptions/{subscription_id}
Returns the stored Subscription API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
subscription_id
string
path
True
ID of the subscription collection to list
Status: 200, Returns the stored Subscription API resource in the JSON response body.
type
string
True
  • "application/astra-subscription"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
id
string
True
customerProfileID
string
True
JSON string containing the customer profile ID from Authorize.net, which was invoked by the UI, is not set for the trial term. Returns an empty string during read operation, if not set. Defined values are:
  • Minimum length: 0
  • Maximum length: 63
paymentProfileID
string
False
JSON string containing the payment profile ID from Authorize.net that was invoked by the UI, not set for trial term. Returns an empty string during read operation if not set. Defined values are:
  • Minimum length: 0
paymentExpiry
string
False
JSON string containing a timestamp indicating when the payment method expires. This is obtained from authorize.net](http://authorize.net) and is set by the UI. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema This field is not returned for trial terms.
purchaseOrderNumber
string
False
JSON string containing the purchase order number for the payment method. Defined values are:
  • Minimum length: 1
  • Maximum length: 31
marketplace
string
False
JSON string indicating the marketplace for an account where payments will be recorded. Defined values:
  • "netapp"
  • "azure"
  • "aws"
  • "gcp"
licenseSN
string
False
JSON string containing the license serial number for the payment method. Defined values are:
  • Minimum length: 1
terms
string
True
JSON string indicating the current tier of the account. Defined values are:
  • "trial"
  • "paid"
status
string
True
JSON string indicating the current status of the subscription. Defined values are:
  • "active"
  • "inactive"
appLimit
number
True
JSON number indicating the application limit for this subscription. Value of -1 indicates no limit.
namespaceLimit
number
True
JSON number indicating the namespace limit for this subscription. Value of -1 indicates no limit.
subscriptionPeriod
number
True
JSON number indicating the subscription period. Value of -1 indicates no limit. Unit: days
gracePeriod
number
True
JSON number indicating the grace period after the trial subscription has expired or a paid subscription is canceled. Unit: days
reminderBeforePeriod
number
True
JSON number indicating the number of days before the end of the trial subscription we should start notifying the customer. Value of -1 indicates N/A. Unit: days
onboardStatus
string
True
JSON string indicating the current status of customer onboarding. Valid values are "not started", "in progress", "success", "failed". Defined values are:
  • "not started"
  • "in progress"
  • "success"
  • "failed"
costPerAppUnit
number
True
JSON number indicating the cost per app unit. For a trial version, the value would be 0. Unit: US dollars
costPerNamespaceUnit
number
True
JSON number indicating the cost per namespace unit. For a trial version, the value would be 0. Unit: US dollars
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-subscription",
  "version": "1.2",
  "id": "40b4106f-b743-5d83-95c7-d539b2b45f63",
  "customerProfileID": "2157047189",
  "paymentProfileID": "E7CEB0A9F1BECA32A02493E1B31D5955",
  "paymentExpiry": "2022-02-01T00:00:00Z",
  "purchaseOrderNumber": "72384632",
  "marketplace": "netapp",
  "licenseSN": "278343",
  "terms": "trial",
  "status": "active",
  "onboardStatus": "success",
  "costPerAppUnit": 0,
  "costPerNamespaceUnit": 0.005,
  "appLimit": 0,
  "namespaceLimit": 10,
  "subscriptionPeriod": 90,
  "gracePeriod": 7,
  "reminderBeforePeriod": 30,
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
