Retrieve a task
Collaboratori
GET /accounts/{account_id}/core/v1/tasks/{task_id}
Returns the stored Task API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
task_id
string
path
True
ID of the task collection to list
Status: 200, Returns the stored Task API resource in the JSON response body.
type
string
True
  • "application/astra-task"
version
string
True
  • "1.0"
id
string
True
name
string
True
JSON string containing a dot notation (.) hierarchical name for the task. Defined values are:
  • Minimum length: 3
  • Maximum length: 127
  • Defined regex is: "^[a-z])(\.([a-z])+$"
summary
string
True
JSON string containing the short-form summary of the task. Defined values are:
  • Minimum length: 3
  • Maximum length: 63
description
string
True
JSON string containing a description of the task. Defined values are:
  • Minimum length: 1
  • Maximum length: 511
service
string
False
JSON string containing the name of the service that is managing the task. Defined values are:
  • Minimum length: 1
  • Maximum length: 31
parentTaskID
string
False
JSON string containing a globally unique identifier of a parent task of the task. Defined values are:
  • Conforms to the Astra Identifier Schema
resourceID
string
True
JSON string containing a globally unique identifier of the resource associated with the task. Defined values are:
resourceURI
string
True
JSON string containing the URI associated with the task. Defined values are:
  • Minimum length: 3
  • Maximum length: 4095
resourceCollectionURI
array[string]
True
JSON array of JSON strings, each indicating the fully-expanded access URL of the resource associated with the task. Defined values are:
  • Minimum length: 3
state
string
True
JSON string containing a value indicating the operational state of the task. Defined values are:
  • "notStarted" - The task has not started executing.
  • "running" - The task is running.
  • "completed" - The task has completed.
  • "pausing" - The task was requested to pause.
  • "paused" - The task is paused.
  • "cancelling" - The task was requested to cancel.
  • "cancelled" - The task is cancelled.
  • "failed" - The task has failed.
  • Minimum length: 1
stateTransitions
array[type_astra_stateTransitions]
True
JSON array of JSON objects, each representing the set of permitted state transitions from a given defined state. Each JSON object contains the fields "from" and "to", where the "from" value is the name of a state, and the "to" value is an array of permitted destination states.
  • Minimum length: 1
  • Maximum length: 31 For example: "stateTransitions" : [ { "from": "running", "to": ["paused", "cancelled"] }, { "from": "paused", "to": ["running", "cancelled"] }, ]
stateDetails
array[type_astra_stateDetails]
True
JSON array of JSON objects that lists additional details about the current "state". This field indicates when there are conditions or errors that prevent the actual state from matching the desired state. If no details are available, this array will be empty.
  • Minimum Items: 0
orderHint
number
False
JSON number representing the order of subtasks. This field can be used by the client to sort subtasks from smallest to largest.
percentDone
number
False
JSON number containing the percentage complete for a running task. When the task is completed, this is set to "100".
startTime
string
False
JSON string containing the timestamp indicating when the task started. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
endTime
string
False
JSON string containing the timestamp indicating when the task ended. Defined values are:
cancelTime
string
False
JSON string containing the timestamp indicating when the task was cancelled. Defined values are:
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-task",
  "version": "1.0",
  "id": "b1c006b2-2ebf-5dfb-994e-e807c184ac0a",
  "name": "astra.backup.prep",
  "summary": "Backup preparation",
  "description": "Task to prepare for the application backup",
  "service": "nautilus",
  "parentTaskID": "9cc8c321-6af1-406c-8158-2c6582c247f8",
  "resourceID": "626a0978-d55f-4841-8b7c-dc0c0f592c6f",
  "resourceURI": "/accounts/fdaa655c-15ab-4d34-aa61-1e9098e67be0/k8s/v1/apps/7c8bef49-697e-4fb4-810c-675cef4cf6c9/appSnaps/2b6dafc3-2172-4431-a482-6306b2703130",
  "resourceCollectionURI": [
    "/accounts/fdaa655c-15ab-4d34-aa61-1e9098e67be0/topology/v1/clouds/0df3f1a0-7203-4c12-aabf-a7bee6302671/clusters/dfd9de2d-6f0b-437b-a737-c8f7f176cd14/namespaces/f8b58091-4b9c-4c64-9b40-018dbaf7c5de/apps/f670bf11-8850-44bd-b330-815af6186a06/appSnaps/2b6dafc3-2172-4431-a482-6306b2703130",
    "/accounts/fdaa655c-15ab-4d34-aa61-1e9098e67be0/topology/v1/clouds/0df3f1a0-7203-4c12-aabf-a7bee6302671/clusters/dfd9de2d-6f0b-437b-a737-c8f7f176cd14/namespaces/923708f8-0435-45b5-8c00-fbdef3ffaf25/apps/f670bf11-8850-44bd-b330-815af6186a06/appSnaps/2b6dafc3-2172-4431-a482-6306b2703130"
  "state": "running",
  "stateTransitions": [
      "from": "running",
      "to": [
        "paused",
        "cancelled"
      "from": "paused",
      "to": [
        "running",
        "cancelled"
  "stateDetails": [],
  "orderHint": 0,
  "percentDone": 20.25,
  "startTime": "2020-08-06T12:24:52.256624Z",
  "endTime": "2020-08-06T12:26:52.256624Z",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
from
string
True
to
array[string]
True
type
string
True
title
string
True
detail
string
True
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
