Retrieve an unread notification
Collaboratori
GET /accounts/{account_id}/core/v1/users/{user_id}/unreadNotifications/{unreadNotification_id}
Returns the stored Unread Notification API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
user_id
string
path
True
ID of the containing user resource
string
path
True
ID of the unreadNotification collection to list
Status: 200, Returns the stored Unread Notification API resource in the JSON response body.
type
string
True
  • "application/astra-unreadNotification"
version
string
True
  • "1.0"
id
string
True
notificationID
string
True
JSON string containing a notification ID that is to be marked as read by the user creating the mark. Defined values are:
  • Conforms to the Astra Identifier Schema
sequenceCount
number
True
JSON number containing a sequence count associated with the notification specified by the notification ID.
severity
string
True
JSON string containing one of the following values that indicate the severity of the event. Defined values are:
  • "cleared" - Indicates that a previously reported event describing a condition is no longer active. An event with severity "cleared" will use the same summary and correlation ID to enable it to be matched up
  • "indeterminate" - Indicates that the severity cannot be determined
  • "informational" - Indicates a change in state that is both expected and normal (not defined in X.733)
  • "warning" - Indicates the detection of a potential or impending service-affecting fault before any significant effects have been felt
  • "critical" - Indicates that a service-affecting condition has occurred and immediate corrective action is required
metadata
type_astra_metadata
True
  • Conforms to the Astra Metadata Schema
  "type": "application/astra-unreadNotification",
  "version": "1.0",
  "id": "10df997b-629e-50f8-bc5f-a18b9a4ac5f6",
  "notificationID": "4080cf5f-2261-4130-b8fb-8432e2e553e6",
  "sequenceCount": 48923,
  "severity": "warning",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
