Retrieve a cloud
Collaboratori
GET /accounts/{account_id}/topology/v1/clouds/{cloud_id}
Returns the stored Cloud API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
cloud_id
string
path
True
ID of the cloud collection to list
Status: 200, Returns the stored Cloud API resource in the JSON response body.
type
string
True
  • "application/astra-cloud"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
name
string
True
JSON string containing the name of the cloud. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • This string is internally validated to prevent XSS, Unicode, directory traversal, and SQL-injection attacks
state
string
True
JSON string containing a value indicating the operational state of the cloud. Defined values are:
  • "pending" - The cloud is scheduled for discovery
  • "discovering" - The cloud is in the process of being discovered
  • "provisioning" - The cloud is in the process of being provisioned
  • "running" - The cloud is running normally
  • "failed" - The cloud is in a permanent failure state
  • "removed" - The cloud is not currently accessible
  • "unknown" - The cloud state cannot be determined
stateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why a cloud is unable to transition to "running" or why it has transitioned to "failed". Defined values are:
  • Minimum length: 1
  • Maximum length: 127
cloudType
string
True
JSON string containing a value indicating the type of cloud. Defined values are:
  • "gcp" - The cloud is provided by Google
  • "azure" - The cloud is provided by Microsoft
  • "aws" - The cloud is provided by Amazon
  • "private" - The cloud is customer managed
credentialID
string
False
JSON string containing a value indicating the ID of the credential that contains the service account for the cloud. This is required for cloudType "gcp", "azure" and "aws". Defined values are:
  • Conforms to the Astra Identifier Schema
defaultBucketID
string
False
JSON string containing the ID of a bucket that is to be used by default when creating backups for applications within the cloud. This is required when cloning applications across clusters and is used as a default if a bucket is not specified when creating backups and schedules. Defined values are:
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-cloud",
  "version": "1.1",
  "id": "1c9512c3-ec62-5ed8-8013-02fc090b9d03",
  "name": "GKE",
  "state": "discovering",
  "stateUnready": [
    "Cloud discovery in progress"
  "cloudType": "gcp",
  "credentialID": "6fa2f917-f730-41b8-9c15-17f531843b31",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
