Retrieve a cluster for a cloud
Collaboratori
GET /accounts/{account_id}/topology/v1/clouds/{cloud_id}/clusters/{cluster_id}
Returns the stored Cluster API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
cloud_id
string
path
True
ID of the containing cloud resource
cluster_id
string
path
True
ID of the cluster collection to list
Status: 200, Returns the stored Cluster API resource in the JSON response body.
type
string
True
  • "application/astra-cluster"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
  • "1.3"
id
string
True
name
string
True
JSON string containing a name for the cluster. If not specified, the Kubernetes name of the cluster will be used. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • This string is internally validated to prevent XSS, Unicode, directory traversal, and SQL-injection attacks
state
string
True
JSON string containing a value indicating the operational state of the cluster. Defined values are:
  • "pending" - The cluster is scheduled for discovery
  • "discovering" - The cluster is in the process of being discovered
  • "provisioning" - The cluster is in the process of being provisioned
  • "running" - The cluster is running normally
  • "failed" - The cluster is in a permanent failure state
  • "removed" - The cluster is not currently accessible
  • "unknown" - The cluster state cannot be determined
stateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why the cluster is unable to transition to "running" state, when there are issues while in "running" state, or why it has transitioned to "failed" or "removed" state. Defined values are:
  • Minimum length: 1
  • Maximum length: 127
managedState
string
True
JSON string containing a value indicating the management state of the cluster. Defined values are:
  • "pending" - The cluster is scheduled to be discovered or added
  • "ineligible" - The cluster is in "running" state, is not under management, and is not eligible for management. The reasons for this ineligibility are provided in the unready key value
  • "unmanaged" - The cluster is in "running" or "failed" state, is not under management, and is eligible for management
  • "managing" - The cluster is in "running" state and is in the process of being managed
  • "managed" - The cluster is in "running", "failed", or "removed" state, and is under management
protectionState
string
True
JSON string containing a value indicating the protection state of the cluster. Defined values are:
  • "full" - The clusters default storage class supports snapshots
  • "partial" - The cluster has only storageClasses that do not support snapshots
  • "atRisk" - The default storage class of the cluster does not support snapshots
protectionStateDetails
array[type_astra_stateDetails]
True
JSON array of JSON objects which lists additional details about the current protection state, including why the current state was reached. If no details are available, this array will be empty. Defined values are:
  • Minimum Items: 0
restoreTargetSupported
string
False
JSON string containing a value indicating the ability of the cluster to be a target of application data management operations. Defined values are:
  • "true" - Cluster is an eligible target for app data management operations.
  • "false" - Cluster is not an eligible target for app data management operations.
snapshotSupported
string
False
JSON string containing a value indicating the ability of the cluster to perform application data management backup-like operations. Defined values are:
  • "true" - Cluster is eligible to perform app data management operations.
  • "false" - Cluster is not eligible to perform app data management operations.
managedStateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why the cluster is ineligible to be managed, or that the cluster is managed but non-fatal errors were encountered while managing the cluster. Defined values are:
  • Minimum length: 1
managedTimestamp
string
False
JSON string containing the timestamp indicating when the cluster was brought under management. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema This key is only returned when a cluster has a managedState of "managed".
tridentVersion
string
False
JSON string containing the version of Trident installed on the cluster. Defined values are:
  • Conforms to the Software Version Schema
tridentManagedState
string
False
JSON string containing one of a set of enumerated values indicating the management state of Trident on this cluster. Defined values are:
  • "managed" - Trident instance on the cluster is managed by Astra
  • "unmanaged" - Trident instance on the cluster is not managed by Astra
tridentManagedStateDesired
string
False
JSON string containing a value indicating the desired management state for Trident. Defined values are:
  • "managed" - Manage Trident on this cluster
  • "unmanaged" - Do not manage Trident on this cluster
tridentManagedStateDetails
False
JSON array of JSON objects that lists additional details about why the state transitioned to "managed" or "unmanaged".
  • Minimum items: 0
tridentManagedStateAllowed
array[string]
False
States that can be requested in a given tridentManagedState. The following states can be requested in each defined state:
  • "managed": "managed"
  • "unmanaged": "unmanaged"
inUse
string
True
JSON string containing a value indicating if the cluster has any managed applications and therefore cannot be deleted. Defined values are:
  • "false" - The cluster is not managed or is managed but has no managed applications associated with it
  • "true" - The cluster is managed and has managed applications associated with it
accHost
string
False
JSON string that indicates that this cluster hosts the instance of Astra Control Center that is currently being accessed. Defined values are:
  • "true" - This cluster is hosting the instance of Astra Control Center that is currently being accessed.
clusterType
string
True
JSON string containing a value indicating the type of cluster. Defined values are:
  • "gke" - Kubernetes hosted on Google Kubernetes Engine
  • "aks" - Kubernetes hosted on Microsoft Azure Kubernetes Service
  • "eks" - Kubernetes hosted on Amazon Elastic Kubernetes Service
  • "rke" - The cluster is of type Rancher
  • "tanzu" -The cluster is of type Tanzu Kubernetes Grid
  • "openshift" - The cluster is of type OpenShift
  • "kubernetes" - The cluster is generic Kubernetes
clusterVersion
string
False
JSON string containing a value indicating the semantic versioning representation of the cluster environment. For Kubernetes clusters, this is the Kubernetes version. Defined values are:
  • Minimum length: 1
  • Maximum length: 31
clusterVersionString
string
False
JSON string containing a value indicating the extended versioning information for the cluster environment. For Kubernetes clusters, this is the full Kubernetes version. Defined values are:
  • Minimum length: 1
clusterCreationTimestamp
string
False
JSON string containing the timestamp indicating when the cluster was originally created. Defined values are:
namespaces
array[string]
False
JSON array of JSON strings, each indicating a namespace within the cluster. Defined values are:
  • Minimum length: 1
  • Maximum length: 253
defaultStorageClass
string
False
JSON string containing a storageClass ID that corresponds to the default storage class set in Kubernetes. Defined values are:
  • Conforms to the Astra Identifier Schema
cloudID
string
True
JSON string containing a value indicating the ID of the cloud the cluster is running on. Defined values are:
credentialID
string
False
JSON string containing a value indicating the ID of the credential that contains the kubeconfig file for the cluster. Defined values are:
location
string
False
JSON string containing a value provided by the cloud that the cluster is running on, indicating the cloud-specific location of the cluster. Defined values are:
  • Minimum length: 1
isMultizonal
string
False
JSON string containing a value provided by the cloud the cluster is running on, indicating whether the cluster spans two or more availability zones. Defined values are:
  • "true" - The cluster spans two or more availability zones
  • "false" - The cluster is wholly located within a single availability zone
privateRouteID
string
False
JSON string containing the location ID for private clusters.
  • Minimum length: 1
  • Maximum length: 255
apiServiceID
string
False
JSON string containing the UUID from the Kubernetes (k8s) API service object. Used to uniquely identify a cluster.
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-cluster",
  "version": "1.3",
  "id": "01eaddc3-75b9-5606-97ae-0aa468b59492",
  "name": "GKE-22",
  "state": "running",
  "stateUnready": [],
  "managedState": "unmanaged",
  "managedStateUnready": [],
  "protectionState": "full",
  "protectionStateDetails": [],
  "tridentVersion": "21.07.2",
  "tridentManagedState": "managed",
  "tridentManagedStateDetails": [],
  "inUse": "false",
  "clusterType": "kubernetes",
  "clusterVersion": "1.91.1",
  "clusterVersionString": "1.19.1",
  "clusterCreationTimestamp": "2020-08-06T12:24:52.256624Z",
  "namespaces": [
    "kube-system",
    "kube-public",
    "my-app-1"
  "defaultStorageClass": "31c95aba-99d9-4987-b1bb-000dfce5952c",
  "cloudID": "548bdc1f-f00e-4a23-a062-83265d224d46",
  "credentialID": "6fa2f917-f730-41b8-9c15-17f531843b31",
  "location": "europe-west4",
  "isMultizonal": "false",
  "apiServiceID": "6bf33af2-872a-4553-a891-26b510c3edbe",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 500, Internal server error
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/65",
  "title": "Cluster GET not performed",
  "detail": "The cluster GET call didn't perform the lookup operation on the cluster.",
  "status": "500"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type
string
True
title
string
True
detail
string
True
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
