Create a new application snapshot for an app
Collaboratori
POST /accounts/{account_id}/k8s/v1/apps/{app_id}/appSnaps
Indicates the desired values for the Application Snapshot API resource to be created.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
Request Body
type
string
True
  • "application/astra-appSnap"
version
string
True
  • "1.0"
  • "1.1"
name
string
False
JSON string containing a user-specified name for the snapshot. If not specified, or when snapshots are initiated by a schedule, the system will assign a name for the snapshot. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • Conforms to the DNS 1123 Label Schema
metadata
type_astra_metadata
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
Example request
  "type": "application/astra-appSnap",
  "version": "1.1",
  "name": "app-name-245"
Status: 201, Returns the newly created appSnap resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
  • "1.1"
id
string
True
name
string
True
  • Minimum length: 1
scheduleID
string
False
JSON string containing an optional schedule ID that indicates that the snapshot was triggered by a schedule and which schedule triggered the snapshot. Only present for snapshots initiated by a schedule. Defined values are:
  • Conforms to the Astra Identifier Schema
snapshotAppAsset
string
False
JSON string containing the ID of the application asset corresponding to the snapshot. This field will be returned when the state of the application snapshot is "completed". Defined values are:
state
string
True
JSON string containing a value indicating the operational state of the snapshot. Defined values are:
  • "pending" - The application snapshot is scheduled for discovery
  • "discovering" - The application snapshot is in the process of being discovered
  • "running" - The application snapshot is running normally
  • "completed" - The application snapshot has completed
  • "failed" - The application snapshot is in a permanent failure state
  • "removed" - The application snapshot is not currently accessible
  • "unknown" - The application snapshot state cannot be determined
stateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why an application snapshot is unable to transition to "running", or why it has transitioned to "failed". Defined values are:
  • Minimum length: 1
  • Maximum length: 127
hookState
string
False
JSON string containing a value indicating the state of any execution hook or hooks running as a part of a snapshot. Defined values are:
  • "failed" - One or more execution hooks have failed
  • "success" - There were zero or more applicable hooks and all were successful
hookStateDetails
array[type_astra_stateDetails]
False
JSON array of JSON objects which lists additional details about why "hookState" transitioned into "failed". If no details are available, this array will be empty.
  • Minimum items: 0
metadata
type_astra_metadata
True
  "version": "1.1",
  "id": "ab41abde-ae1b-5361-ae00-d82deac97bf3",
  "name": "app-name-245",
  "scheduleID": "1fe83650-9b3c-41ef-bb25-a2910c19c33e",
  "state": "pending",
  "stateUnready": [],
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
title
string
True
detail
string
True
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
