Comandi di AIX Host Utilities per la configurazione dello storage ONTAP
È possibile utilizzare il riferimento del comando di esempio delle utilità host AIX per una convalida end-to-end della configurazione di archiviazione NetApp utilizzando lo strumento Utilità host.
Elenca tutti gli iniziatori host mappati all'host
È possibile recuperare un elenco di iniziatori host mappati a un host.
sanlun fcp show adapter -v
8.0
Mostra esempio per AIX Host Utilities 8.0
adapter name: fcs4 WWPN: 100000109bf606a8 WWNN: 200000109bf606a8 driver name: /usr/lib/drivers/pci/emfcdd model: df1000e31410150 model description: FC Adapter serial number: Y050HY22L002 hardware version: Not Available driver version: 7.2.5.201 firmware version: 00014000000057400007 Number of ports: 1 port type: Fabric port state: Operational supported speed: 32 GBit/sec negotiated speed: 32 GBit/sec OS device name: fcs4 adapter name: fcs5 WWPN: 100000109bf606a9 WWNN: 200000109bf606a9 driver name: /usr/lib/drivers/pci/emfcdd model: df1000e31410150 model description: FC Adapter serial number: Y050HY22L002 hardware version: Not Available driver version: 7.2.5.201 firmware version: 00014000000057400007 Number of ports: 1 port type: Fabric port state: Operational supported speed: 32 GBit/sec negotiated speed: 32 GBit/sec OS device name: fcs5 bash-3.2#
7.0 e 6.1
Mostra esempio per AIX Host Utilities 7.0 e 6.1
bash-3.2# sanlun fcp show adapter -v adapter name: fcs0 WWPN: 100000109b22e143 WWNN: 200000109b22e143 driver name: /usr/lib/drivers/pci/emfcdd model: df1000e31410150 model description: FC Adapter serial number: YA50HY79S117 hardware version: Not Available driver version: 7.2.5.0 firmware version: 00012000040025700027 Number of ports: 1 port type: Fabric port state: Operational supported speed: 16 GBit/sec negotiated speed: Unknown OS device name: fcs0 adapter name: fcs1 WWPN: 100000109b22e144 WWNN: 200000109b22e144 driver name: /usr/lib/drivers/pci/emfcdd model: df1000e31410150 model description: FC Adapter serial number: YA50HY79S117 hardware version: Not Available driver version: 7.2.5.0 firmware version: 00012000040025700027 Number of ports: 1 port type: Fabric port state: Operational supported speed: 16 GBit/sec negotiated speed: Unknown OS device name: fcs1 bash-3.2#
Elenca tutti i LUN mappati all'host
È possibile recuperare un elenco di tutti i LUN mappati a un host.
sanlun lun show -p -v all
8.0
LUN: 88 LUN Size: 15g Host Device: hdisk9 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority ----------------------------------------------------- up primary path0 fcs0 fc_aix_1 1 up primary path1 fcs1 fc_aix_2 1 up secondary path2 fcs0 fc_aix_3 1 up secondary path3 fcs1 fc_aix_4 1
7.0 e 6.1
ONTAP Path: vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun LUN: 88 LUN Size: 15g Host Device: hdisk9 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority ----------------------------------------------------- up primary path0 fcs0 fc_aix_1 1 up primary path1 fcs1 fc_aix_2 1 up secondary path2 fcs0 fc_aix_3 1 up secondary path3 fcs1 fc_aix_4 1
Elencare tutti i LUN mappati all'host da una SVM specifica
È possibile recuperare un elenco di tutti i LUN mappati a un host da una SVM specificata.
sanlun lun show -p -v sanboot_unix
8.0
ONTAP Path: sanboot_unix:/vol/aix_205p2_boot_0/boot_205p2_lun LUN: 0 LUN Size: 80.0g Host Device: hdisk85 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority ------------------------------------------------- up primary path0 fcs0 sanboot_1 1 up primary path1 fcs1 sanboot_2 1 up secondary path2 fcs0 sanboot_3 1 up secondary path3 fcs1 sanboot_4 1
7.0 e 6.1
Elencare tutti gli attributi di un LUN assegnato all'host
È possibile recuperare un elenco di tutti gli attributi di un LUN specificato mappato a un host.
sanlun lun show -p -v vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun
8.0
ONTAP Path: vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun LUN: 88 LUN Size: 15g Host Device: hdisk9 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority --------------------------------------------------------- up primary path0 fcs0 fc_aix_1 1 up primary path1 fcs1 fc_aix_2 1 up secondary path2 fcs0 fc_aix_3 1 up secondary path3 fcs1 fc_aix_4 1
7.0 e 6.1
Elencare gli attributi del LUN ONTAP in base al nome del file del dispositivo host
È possibile recuperare un elenco di attributi del LUN ONTAP specificando un nome file del dispositivo host.
sanlun lun show -d /dev/hdisk1
8.0
controller(7mode)/ device host lun vserver(Cmode) lun-pathname ----------------------------------------------------------------------------- vs_aix_clus /vol/gpfs_205p2_207p1_vol_0_0/aix_205p2_207p1_lun filename adapter protocol size mode ----------------------------------- hdisk1 fcs0 FCP 15g C
7.0 e 6.1
Elenca tutte le WWPN LIF di destinazione SVM collegate all'host
È possibile recuperare un elenco di tutte le WWPN LIF di destinazione SVM collegate a un host.
sanlun lun show -wwpn
8.0
controller(7mode)/ target device host lun vserver(Cmode) wwpn lun-pathname -------------------------------------------------------------------------------- vs_aix_clus 203300a098ba7afe /vol/gpfs_205p2_207p1_vol_0_0/aix_205p2_207p1_lun vs_aix_clus 203300a098ba7afe /vol/gpfs_205p2_207p1_vol_0_9/aix_205p2_207p1_lun vs_aix_clus 203300a098ba7afe /vol/gpfs_205p2_207p1_vol_en_0_0/aix_205p2_207p1_lun_en vs_aix_clus 202f00a098ba7afe /vol/gpfs_205p2_207p1_vol_en_0_1/aix_205p2_207p1_lun_en filename adapter size mode ----------------------------------- hdisk1 fcs0 15g C hdisk10 fcs0 15g C hdisk11 fcs0 15g C hdisk12 fcs0 15g C
7.0 e 6.1
