Comandi di Linux Host Utilities per la configurazione dello storage ONTAP
È possibile utilizzare il riferimento ai comandi di esempio di Linux Host Utilities per una convalida end-to-end della configurazione di storage NetApp mediante lo strumento Host Utilities.
Elenca tutti gli iniziatori host mappati all'host
È possibile recuperare un elenco di tutti gli iniziatori host mappati a un host.
sanlun fcp show adapter -v
Mostra esempio
adapter name: host15 WWPN: 10000090fa022736 WWNN: 20000090fa022736 driver name: lpfc model: LPe16002B-M6 model description: Emulex LPe16002B-M6 PCIe 2-port 16Gb Fibre Channel Adapter serial number: FC24637890 hardware version: 0000000b 00000010 00000000 driver version: 12.8.0.5; HBAAPI(I) v2.3.d, 07-12-10 firmware version: 12.8.340.8 Number of ports: 1 port type: Fabric port state: Operational supported speed: 4 GBit/sec, 8 GBit/sec, 16 GBit/sec negotiated speed: 16 GBit/sec OS device name: /sys/class/scsi_host/host15 adapter name: host16 WWPN: 10000090fa022737 WWNN: 20000090fa022737 driver name: lpfc model: LPe16002B-M6 model description: Emulex LPe16002B-M6 PCIe 2-port 16Gb Fibre Channel Adapter serial number: FC24637890 hardware version: 0000000b 00000010 00000000 driver version: 12.8.0.5; HBAAPI(I) v2.3.d, 07-12-10 firmware version: 12.8.340.8 Number of ports: 1 port type: Fabric port state: Operational supported speed: 4 GBit/sec, 8 GBit/sec, 16 GBit/sec negotiated speed: 16 GBit/sec OS device name: /sys/class/scsi_host/host16
Elenca tutti i LUN mappati all'host
È possibile recuperare un elenco di tutti i LUN mappati a un host.
sanlun lun show -p -v all
Mostra esempio
ONTAP Path: vs_sanboot:/vol/sanboot_169/lun
LUN: 0
LUN Size: 150g
Product: cDOT
Host Device: 3600a0980383143393124515873683561
Multipath Policy: service-time 0
DM-MP Features: 3 queue_if_no_path pg_init_retries 50
Hardware Handler: 1 alua
Multipath Provider: Native
host vserver host:
dm-mp path path /dev/ chan: vserver major:
state state type node id:lun LIF minor
active up primary sdq 15:0:5:0 lif_18 65:0
active up primary sds 16:0:5:0 lif_17 65:32
active up primary sdac 16:0:7:0 lif_25 65:192
active up primary sdad 15:0:7:0 lif_26 65:208
active up secondary sdt 15:0:4:0 lif_20 65:48
active up secondary sdr 15:0:6:0 lif_19 65:16
active up secondary sdad 16:0:4:0 lif_27 66:96
active up secondary sdan 16:0:6:0 lif_28 66:112
Elencare tutti i LUN mappati all'host da una SVM specifica
È possibile recuperare un elenco di tutti i LUN mappati a un host da una specifica macchina virtuale di storage (SVM).
sanlun lun show -p -v vs_sanboot
Mostra esempio
LUN: 0
LUN Size: 160g
Product: cDOT
host vserver host:
active up primary sdce 15:0:5:0 lif_16g_5 69:32
active up primary sdfk 16:0:5:0 lif_16g_7 130:96
active up primary sdfm 16:0:7:0 lif_16g_8 130:128
active up primary sdcg 15:0:7:0 lif_16g_6 69:64
active up secondary sdcd 15:0:4:0 lif_16g_1 69:16
active up secondary sdcf 15:0:6:0 lif_16g_2 69:48
active up secondary sdfj 16:0:4:0 lif_16g_3 130:80
active up secondary sdfl 16:0:6:0 lif_16g_4 130:112
Elencare tutti gli attributi di un LUN assegnato all'host
È possibile recuperare un elenco di tutti gli attributi di un LUN specificato mappato a un host.
sanlun lun show -p -v vs_sanboot:/vol/sanboot_169/lun
Mostra esempio
LUN: 0
LUN Size: 160g
Product: cDOT
host vserver host:
Elencare l'identità SVM ONTAP da cui viene mappata una determinata LUN all'host
È possibile recuperare un elenco di identità SVM ONTAP da cui viene mappato un LUN specifico a un hist.
sanlun lun show -m -v vs_sanboot:/vol/sanboot_169/lun
Mostra esempio
device host lun
vserver lun-pathname filename adapter protocol size product
vs_sanboot /vol/sanboot_169/lun /dev/sdfm host16 FCP 160g cDOT
LUN Serial number: 81C91$QXsh5a
Controller Model Name: AFF-A400
Vserver FCP nodename: 2008d039ea1308e5
Vserver FCP portname: 2010d039ea1308e5
Vserver LIF name: lif_16g_8
Vserver IP address: 10.141.12.165
10.141.12.161
10.141.12.163
Vserver volume name: sanboot_169 MSID::0x000000000000000000000000809E7CC3
Vserver snapshot name:
Elencare gli attributi del LUN ONTAP in base al nome del file del dispositivo host
È possibile recuperare un elenco di attributi del LUN ONTAP in base al nome del file del dispositivo host.
sanlun lun show -d /dev/sdce
Mostra esempio
controller(7mode/E-Series)/ device host lun vserver(cDOT/FlashRay) lun-pathname filename adapter protocol size product ---------------------------------------------------------------------------------------------------- vs_sanboot /vol/sanboot_169/lun /dev/sdce host15 FCP 160g cDOT [root@sr630-13-169 ~]#
Elenca tutte le WWPN LIF di destinazione SVM collegate all'host
È possibile recuperare un elenco di tutte le WWPN LIF di destinazione SVM collegate a un host.
sanlun lun show -wwpn
Mostra esempio
controller(7mode/E-Series)/ target device host lun vserver(cDOT/FlashRay) wwpn lun-pathname filename adapter size product ----------------------------------------------------------------------------------------------------------------------- vs_169_16gEmu 202cd039ea1308e5 /vol/VOL_8g_169_2_8/lun /dev/sdlo host18 10g cDOT vs_169_16gEmu 202cd039ea1308e5 /vol/VOL_8g_169_2_9/lun /dev/sdlp host18 10g cDOT vs_169_16gEmu 202cd039ea1308e5 /vol/VOL_8g_169_2_7/lun /dev/sdln host18 10g cDOT vs_169_16gEmu 202cd039ea1308e5 /vol/VOL_8g_169_2_5/lun /dev/sdll host18 10g cDOT
Elencare le LUN ONTAP visualizzate sull'host da una data LIF WWPN di destinazione SVM
È possibile recuperare un elenco di LUN ONTAP rilevati su un host da una LIF WWPN di destinazione SVM specificata.
sanlun lun show -wwpn 2010d039ea1308e5
Mostra esempio
controller(7mode/E-Series)/ target device host lun vserver(cDOT/FlashRay) wwpn lun-pathname filename adapter size product --------------------------------------------------------------------------------------------------------------- vs_sanboot 2010d039ea1308e5 /vol/sanboot_169/lun /dev/sdfm host16 160g cDOT
