slptool findattrs
Il slptool findattrs Command trova gli attributi WBEM in esecuzione in una rete.
Sintassi
slptool findattrs service
Posizione
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Livello di privilegio
Un utente con un nome utente e una password validi
Parametri
serviceSpecifica il tipo di servizio.
Esempio
Il slptool findattrs comando e relativo output abbreviato:
slptool findattrs service:wbem (template-url-syntax=http://10.229.90.227:5988),(service-id=PG:10-229-90-227),(service-hi-name=Pegasus),(service-hi-description=Pegasus CIM Server Version 2.12.0),(template-type=wbem),(template-version=1.0),(template-description=This template describes the attributes used for advertising Pegasus CIM Servers.),(InteropSchemaNamespace=interop),(FunctionalProfilesSupported=Basic Read,Basic Write,Schema Manipulation,Instance Manipulation,Association Traversal,Qualifier Declaration,Indications),(MultipleOperationsSupported=TRUE),(AuthenticationMechanismsSupported=Basic),(AuthenticationMechanismDescriptions=Basic),(CommunicationMechanism=CIM-XML),(ProtocolVersion=1.0),(Namespace=root/PG_Internal,interop,root/ontap,root),(RegisteredProfilesSupported=SNIA:Server,SNIA:Array,SNIA:NAS Head,SNIA:Software,SNIA:Profile Registration,SNIA:SCNAS,SNIA:Storage Virtualizer,SNIA:Indication)
