本製品の最新リリースがご利用いただけます。
Create a new ASUP resource
共同作成者
POST /accounts/{account_id}/core/v1/asups
Indicates the desired values for the ASUP API resource to be created.
account_id
string
path
True
  • example: {{.Account}}
Request Body
type
string
True
  • "application/astra-asup"
version
string
True
  • "1.0"
upload
string
True
JSON string containing a value indicating whether to upload the AutoSupport bundle after successful creation. Defined values are:
  • "true" - Upload the AutoSupport bundle.
  • "false" - Do not upload the AutoSupport bundle.
dataWindowStart
string
False
JSON string containing a timestamp indicating the start time of the AutoSupport bundle data collection window. Defaults to 24 hours before the "dataWindowEnd" key value. Must occur before the "dataWindowEnd" key value. Maximum is 7 days before the current time of the request. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
dataWindowEnd
string
False
JSON string containing a timestamp indicating the end time of the AutoSupport bundle data collection window. Defaults to the current time of the request. Defined values are:
metadata
type_astra_metadata
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
Example request
  "type": "application/astra-asup",
  "version": "1.0",
  "upload": "true"
Status: 201, Returns the newly created asup resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
id
string
True
creationState
string
True
JSON string containing a value indicating the creation state of the AutoSupport bundle. For "completed" and "partial" states, the bundle can be downloaded by performing a GET of the resource URI with an Accept header containing "/" or "application/gzip". Defined values are:
  • "running" - AutoSupport bundle generation is running normally.
  • "completed" - AutoSupport bundle generation has completed.
  • "partial" - AutoSupport bundle generation has completed but some data was not included in the bundle.
  • "failed" - AutoSupport bundle generation is in a permanent failure state.
creationStateDetails
array[type_astra_stateDetails]
True
JSON array of JSON objects that lists additional details about why "creationState" transitioned into "partial" or "failed". If no details are available, this array will be empty.
  • Minimum items: 0
upload
string
True
uploadState
string
False
JSON string containing a value that indicates the state of the AutoSupport bundle upload if it was requested. Defined values are:
  • "pending" - AutoSupport bundle upload is scheduled for when AutoSupport bundle creation completes ("creationState" is "running").
  • "blocked" - AutoSupport bundle upload was not attempted because the bundle was not created ("creationState" is "failed") or upload was blocked because there is no license.
  • "running" - AutoSupport bundle upload is running normally ("creationState" is "completed" or "partial").
  • "completed" - AutoSupport bundle upload has completed.
  • "failed" - AutoSupport bundle upload is in a permanent failure state.
uploadStateDetails
False
JSON array of JSON objects that lists additional details about why "uploadState" transitioned into "failed". If no details are available, this array will be empty.
  • Minimum items: 0
triggerType
string
True
JSON string containing a value that indicates what triggered the creation of the asup resource. Defined values are:
  • "manual" - The asup resource and associated AutoSupport bundle were created manually.
  • "scheduled" - The asup resource and associated AutoSupport bundle were created according to a configured schedule.
dataWindowStart
string
True
dataWindowEnd
string
True
metadata
type_astra_metadata
True
  "version": "1.0",
  "id": "9950003f-a1c7-5ca7-8930-06eec25f60aa",
  "creationState": "running",
  "creationStateDetails": [],
  "upload": "true",
  "uploadState": "pending",
  "uploadStateDetails": [],
  "triggerType": "manual",
  "dataWindowStart": "2020-08-05T12:24:00.000000Z",
  "dataWindowEnd": "2020-08-06T12:24:52.000000Z",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
title
string
True
detail
string
True
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
