本製品の最新リリースがご利用いただけます。
Create a new hook source
共同作成者
POST /accounts/{account_id}/core/v1/hookSources
Indicates the desired values for the Hook Source API resource to be created.
account_id
string
path
True
  • example: {{.Account}}
Request Body
type
string
True
  • "application/astra-hookSource"
version
string
True
  • "1.0"
name
string
True
JSON string containing a user-specified name for the resource. Defined values are:
  • Minimum length: 1
  • Maximum length: 63 The name is required to be unique within all hook source resources.
sourceType
string
True
JSON string defining the hook source type. Defined values are:
  • "script" - Shell script. The plaintext source must not contain binary data or carriage-return characters, otherwise, an error is returned.
source
string
True
JSON string containing the script to be run in base64 format. Defined values are:
  • Minimum length: 0
  • Maximum length: 131072
  • Conforms to the base64 Encoded Data Schema The maximum size of a source value is 128 KiB when encoded using base64.
description
string
False
JSON string containing a user-specified description of the hook source. Defined values are:
  • Minimum length: 0
  • Maximum length: 511
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-hookSource",
  "version": "1.0",
  "name": "Payroll script",
  "sourceType": "script",
  "source": "ZWNobyAiVkhKaGJuTWdVbWxuYUhSeklRPT0iIHwgYmFzZTY0IC1k",
  "description": "Pre and post hook script for payroll"
JSON
Status: 201, Returns the newly created hookSource resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
id
string
True
name
string
True
  • Minimum length: 1
private
string
True
JSON string indicating whether the source field will be exposed in APIs or be intentionally left blank. Defined values are:
  • "true" - The source value is private and will not be exposed through the API.
  • "false" - The source value is not private and will be exposed through the API.
preloaded
string
True
JSON string that indicates whether the source was preloaded. Defined values are:
  • "true" - The source was preloaded.
  • "false" - The source was not preloaded. Preloaded hook source resources are read only.
sourceType
string
True
source
string
False
  • Minimum length: 0
sourceMD5Checksum
string
True
JSON string containing the MD5 checksum computed for the value of the "source" key. Defined values are:
  • Defined regex is: "^([0-9a-fA-F]){32}$"
description
string
False
  • Minimum length: 0
metadata
True
  "version": "1.0",
  "id": "fae6dfbb-ecb8-58ff-a116-6357eb7c956a",
  "private": "false",
  "preloaded": "false",
  "sourceMD5Checksum": "b1a4b8b0144c3f6be553b626130ca145",
  "description": "Pre and post hook script for payroll",
  "metadata": {
    "labels": [],
JSON
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
JSON
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
JSON
Status: 409, Conflict
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
JSON
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
JSON
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
JSON
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
Looking for answers?
Try Doc, our Gen AI Assistant.
