Create a new role binding for a user
POST /accounts/{account_id}/core/v1/users/{user_id}/roleBindings
Indicates desired values for the Role Binding API resource to be created.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
user_id |
string |
path |
True |
ID of the containing user resource |
Request Body
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
userID |
string |
False |
JSON string containing a user resource ID. Defined values are:
groupID |
string |
False |
JSON string containing a group resource ID. Defined values are:
accountID |
string |
True |
JSON string containing the ID of an account resource. For create, this must match the account ID in the request URI. Defined values are:
role |
string |
True |
JSON string containing one of the four defined roles. Defined values are:
roleConstraints |
array[string] |
False |
JSON array of JSON strings specifying the scope of the role assignment. Defined values are:
metadata |
False |
Example request
Status: 201, Returns the newly created roleBinding resource in the JSON response body.
type |
string |
True |
version |
string |
True |
id |
string |
True |
principalType |
string |
True |
JSON string representing the type of the principal this binding is associated with. Defined values are:
userID |
string |
True |
groupID |
string |
True |
accountID |
string |
True |
role |
string |
True |
roleConstraints |
array[string] |
False |
metadata |
True |
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
