NetApp Solutions
GPFS para etapas detalhadas do NFS
Colaboradores
Esta seção fornece as etapas detalhadas necessárias para configurar GPFS e mover dados para o NFS usando o NetApp XCP.
Configurar GPFS
  1. Baixe e instale o Spectrum Scale Data Access para Linux em um dos servidores.
    [root@mastr-51 Spectrum_Scale_Data_Access-5.0.3.1-x86_64-Linux-install_folder]# ls
    [root@mastr-51 Spectrum_Scale_Data_Access-5.0.3.1-x86_64-Linux-install_folder]# chmod +x Spectrum_Scale_Data_Access-5.0.3.1-x86_64-Linux-install
    [root@mastr-51 Spectrum_Scale_Data_Access-5.0.3.1-x86_64-Linux-install_folder]# ./Spectrum_Scale_Data_Access-5.0.3.1-x86_64-Linux-install --manifest
    manifest
    <contents removes to save page space>
  2. Instale o pacote pré-requisito (incluindo o chef e os cabeçalhos do kernel) em todos os nós.
    [root@mastr-51 5.0.3.1]# for i in 51 53 136 138 140  ; do ssh 10.63.150.$i "hostname; rpm -ivh  /gpfs_install/chef* "; done
    mastr-51.netapp.com
    warning: /gpfs_install/chef-13.6.4-1.el7.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 83ef826a: NOKEY
    Preparing...                          ########################################
    package chef-13.6.4-1.el7.x86_64 is already installed
    mastr-53.netapp.com
    Updating / installing...
    chef-13.6.4-1.el7                     ########################################
    Thank you for installing Chef!
    workr-136.netapp.com
    workr-138.netapp.com
    workr-140.netapp.com
    [root@mastr-51 installer]# for i in 51 53 136 138 140  ; do ssh 10.63.150.$i "hostname; yumdownloader kernel-headers-3.10.0-862.3.2.el7.x86_64 ; rpm -Uvh --oldpackage kernel-headers-3.10.0-862.3.2.el7.x86_64.rpm"; done
    mastr-51.netapp.com
    Loaded plugins: priorities, product-id, subscription-manager
    kernel-headers-3.10.0-862.3.2.el7     ########################################
    Cleaning up / removing...
    kernel-headers-3.10.0-957.21.2.el7    ########################################
    mastr-53.netapp.com
    Loaded plugins: product-id, subscription-manager
    kernel-headers-3.10.0-862.11.6.el7    ########################################
    Repository ambari-2.7.3.0 is listed more than once in the configuration
    package kernel-headers-3.10.0-862.3.2.el7.x86_64 is already installed
  3. Desative o SELinux em todos os nós.
    [root@mastr-51 5.0.3.1]# for i in 51 53 136 138 140  ; do ssh 10.63.150.$i "hostname; sudo setenforce 0"; done
    mastr-51.netapp.com
    setenforce: SELinux is disabled
    mastr-53.netapp.com
  4. Configure o nó de instalação.
    [root@mastr-51 installer]# ./spectrumscale setup -s 10.63.150.51
    [ INFO  ] Installing prerequisites for install node
    [ INFO  ] Existing Chef installation detected. Ensure the PATH is configured so that chef-client and knife commands can be run.
    [ INFO  ] Your control node has been configured to use the IP 10.63.150.51 to communicate with other nodes.
    [ INFO  ] Port 8889 will be used for chef communication.
    [ INFO  ] Port 10080 will be used for package distribution.
    [ INFO  ] Install Toolkit setup type is set to Spectrum Scale (default). If an ESS is in the cluster, run this command to set ESS mode: ./spectrumscale setup -s server_ip -st ess
    [ INFO  ] SUCCESS
    [ INFO  ] Tip : Designate protocol, nsd and admin nodes in your environment to use during install:./spectrumscale -v node add <node> -p  -a -n
  5. Adicione o nó admin e o nó GPFS ao arquivo de definição de cluster.
    [root@mastr-51 installer]# ./spectrumscale node add mastr-51 -a
    [ INFO  ] Adding node mastr-51.netapp.com as a GPFS node.
    [ INFO  ] Setting mastr-51.netapp.com as an admin node.
    [ INFO  ] Configuration updated.
    [ INFO  ] Tip : Designate protocol or nsd nodes in your environment to use during install:./spectrumscale node add <node> -p -n
  6. Adicione o nó do gerente e o nó GPFS.
    [root@mastr-51 installer]# ./spectrumscale node add mastr-53 -m
    [ INFO  ] Adding node mastr-53.netapp.com as a GPFS node.
    [ INFO  ] Adding node mastr-53.netapp.com as a manager node.
  7. Adicione o nó de quorum e o nó GPFS.
    [root@mastr-51 installer]# ./spectrumscale node add workr-136 -q
    [ INFO  ] Adding node workr-136.netapp.com as a GPFS node.
    [ INFO  ] Adding node workr-136.netapp.com as a quorum node.
  8. Adicione os servidores NSD e o nó GPFS.
    [root@mastr-51 installer]# ./spectrumscale node add workr-138 -n
    [ INFO  ] Adding node workr-138.netapp.com as a GPFS node.
    [ INFO  ] Adding node workr-138.netapp.com as an NSD server.
    [ INFO  ] Tip :If all node designations are complete, add NSDs to your cluster definition and define required filessytems:./spectrumscale nsd add <device> -p <primary node> -s <secondary node> -fs <file system>
  9. Adicione os nós GUI, admin e GPFS.
    [root@mastr-51 installer]# ./spectrumscale node add workr-136 -g
    [ INFO  ] Setting workr-136.netapp.com as a GUI server.
    [root@mastr-51 installer]# ./spectrumscale node add workr-136 -a
    [ INFO  ] Setting workr-136.netapp.com as an admin node.
  10. Adicione outro servidor GUI.
    [root@mastr-51 installer]# ./spectrumscale node add mastr-53 -g
    [ INFO  ] Setting mastr-53.netapp.com as a GUI server.
  11. Adicione outro nó GPFS.
    [root@mastr-51 installer]# ./spectrumscale node add workr-140
    [ INFO  ] Adding node workr-140.netapp.com as a GPFS node.
  12. Verifique e liste todos os nós.
    [root@mastr-51 installer]# ./spectrumscale node list
    [ INFO  ] List of nodes in current configuration:
    [ INFO  ] [Installer Node]
    [ INFO  ] 10.63.150.51
    [ INFO  ]
    [ INFO  ] [Cluster Details]
    [ INFO  ] No cluster name configured
    [ INFO  ] Setup Type: Spectrum Scale
    [ INFO  ]
    [ INFO  ] [Extended Features]
    [ INFO  ] File Audit logging     : Disabled
    [ INFO  ] Watch folder           : Disabled
    [ INFO  ] Management GUI         : Enabled
    [ INFO  ] Performance Monitoring : Disabled
    [ INFO  ] Callhome               : Enabled
    [ INFO  ]
    [ INFO  ] GPFS                 Admin  Quorum  Manager   NSD   Protocol   GUI   Callhome   OS   Arch
    [ INFO  ] Node                  Node   Node     Node   Server   Node    Server  Server
    [ INFO  ] mastr-51.netapp.com    X                                                      rhel7  x86_64
    [ INFO  ] mastr-53.netapp.com                    X                        X             rhel7  x86_64
    [ INFO  ] workr-136.netapp.com   X       X                                X             rhel7  x86_64
    [ INFO  ] workr-138.netapp.com                           X                              rhel7  x86_64
    [ INFO  ] workr-140.netapp.com                                                          rhel7  x86_64
    [ INFO  ]
    [ INFO  ] [Export IP address]
    [ INFO  ] No export IP addresses configured
  13. Especifique um nome de cluster no arquivo de definição de cluster.
    [root@mastr-51 installer]# ./spectrumscale config gpfs -c mastr-51.netapp.com
    [ INFO  ] Setting GPFS cluster name to mastr-51.netapp.com
  14. Especifique o perfil.
    [root@mastr-51 installer]# ./spectrumscale config gpfs -p default
    [ INFO  ] Setting GPFS profile to default
    Profiles options: default [gpfsProtocolDefaults], random I/O [gpfsProtocolsRandomIO], sequential I/O [gpfsProtocolDefaults], random I/O [gpfsProtocolRandomIO]
  15. Especifique o binário de shell remoto a ser usado pelos GPFS; use -r argument.
    [root@mastr-51 installer]# ./spectrumscale config gpfs -r /usr/bin/ssh
    [ INFO  ] Setting Remote shell command to /usr/bin/ssh
  16. Especifique o binário de cópia de arquivo remoto a ser usado pelos GPFS; use -rc argument.
    [root@mastr-51 installer]# ./spectrumscale config gpfs -rc /usr/bin/scp
    [ INFO  ] Setting Remote file copy command to /usr/bin/scp
  17. Especifique o intervalo de portas a ser definido em todos os nós GPFS; use -e argument.
    [root@mastr-51 installer]# ./spectrumscale config gpfs -e 60000-65000
    [ INFO  ] Setting GPFS Daemon communication port range to 60000-65000
  18. Veja as configurações GPFS.
    [root@mastr-51 installer]# ./spectrumscale config gpfs --list
    [ INFO  ] Current settings are as follows:
    [ INFO  ] GPFS cluster name is mastr-51.netapp.com.
    [ INFO  ] GPFS profile is default.
    [ INFO  ] Remote shell command is /usr/bin/ssh.
    [ INFO  ] Remote file copy command is /usr/bin/scp.
    [ INFO  ] GPFS Daemon communication port range is 60000-65000.
  19. Adicione um nó de administrador.
    [root@mastr-51 installer]# ./spectrumscale node add 10.63.150.53 -a
    [ INFO  ] Setting mastr-53.netapp.com as an admin node.
  20. Desative a coleta de dados e carregue o pacote de dados para o IBM Support Center.
    [root@mastr-51 installer]# ./spectrumscale callhome disable
    [ INFO  ] Disabling the callhome.
  21. Ativar NTP.
    [root@mastr-51 installer]# ./spectrumscale config ntp -e on
    [root@mastr-51 installer]# ./spectrumscale config ntp -l
    [ WARN  ] No value for Upstream NTP Servers(comma separated IP's with NO space between multiple IPs) in clusterdefinition file.
    [root@mastr-51 installer]# ./spectrumscale config ntp -s 10.63.150.51
    [ WARN  ] The NTP package must already be installed and full bidirectional access to the UDP port 123 must be allowed.
    [ WARN  ] If NTP is already running on any of your nodes, NTP setup will be skipped. To stop NTP run 'service ntpd stop'.
    [ WARN  ] NTP is already on
    [ INFO  ] Setting Upstream NTP Servers(comma separated IP's with NO space between multiple IPs) to 10.63.150.51
    [ INFO  ] Upstream NTP Servers(comma separated IP's with NO space between multiple IPs) is 10.63.150.51.
    [root@mastr-51 installer]# service ntpd start
    Redirecting to /bin/systemctl start ntpd.service
    [root@mastr-51 installer]# service ntpd status
    Redirecting to /bin/systemctl status ntpd.service
    ● ntpd.service - Network Time Service
       Loaded: loaded (/usr/lib/systemd/system/ntpd.service; enabled; vendor preset: disabled)
       Active: active (running) since Tue 2019-09-10 14:20:34 UTC; 1s ago
      Process: 2964 ExecStart=/usr/sbin/ntpd -u ntp:ntp $OPTIONS (code=exited, status=0/SUCCESS)
     Main PID: 2965 (ntpd)
       CGroup: /system.slice/ntpd.service
               └─2965 /usr/sbin/ntpd -u ntp:ntp -g
    Sep 10 14:20:34 mastr-51.netapp.com ntpd[2965]: ntp_io: estimated max descriptors: 1024, initial socket boundary: 16
    Sep 10 14:20:34 mastr-51.netapp.com ntpd[2965]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
    Sep 10 14:20:34 mastr-51.netapp.com ntpd[2965]: Listen and drop on 1 v6wildcard :: UDP 123
    Sep 10 14:20:34 mastr-51.netapp.com ntpd[2965]: Listen normally on 2 lo 127.0.0.1 UDP 123
    Sep 10 14:20:34 mastr-51.netapp.com ntpd[2965]: Listen normally on 3 enp4s0f0 10.63.150.51 UDP 123
    Sep 10 14:20:34 mastr-51.netapp.com ntpd[2965]: Listen normally on 4 lo ::1 UDP 123
    Sep 10 14:20:34 mastr-51.netapp.com ntpd[2965]: Listen normally on 5 enp4s0f0 fe80::219:99ff:feef:99fa UDP 123
    Sep 10 14:20:34 mastr-51.netapp.com ntpd[2965]: Listening on routing socket on fd #22 for interface updates
    Sep 10 14:20:34 mastr-51.netapp.com ntpd[2965]: 0.0.0.0 c016 06 restart
    Sep 10 14:20:34 mastr-51.netapp.com ntpd[2965]: 0.0.0.0 c012 02 freq_set kernel 11.890 PPM
  22. Pré-verifique as configurações antes de instalar.
    [root@mastr-51 installer]# ./spectrumscale install -pr
    [ INFO  ] Logging to file: /usr/lpp/mmfs/5.0.3.1/installer/logs/INSTALL-PRECHECK-10-09-2019_14:51:43.log
    [ INFO  ] Validating configuration
    [ INFO  ] Performing Chef (deploy tool) checks.
    [ WARN  ] NTP is already running on: mastr-51.netapp.com. The install toolkit will no longer setup NTP.
    [ INFO  ] Node(s): ['workr-138.netapp.com'] were defined as NSD node(s) but the toolkit has not been told about any NSDs served by these node(s) nor has the toolkit been told to create new NSDs on these node(s). The install will continue and these nodes will be assigned server licenses.  If NSDs are desired, either add them to the toolkit with <./spectrumscale nsd add> followed by a <./spectrumscale install> or add them manually afterwards using mmcrnsd.
    [ INFO  ] Install toolkit will not configure file audit logging as it has been disabled.
    [ INFO  ] Install toolkit will not configure watch folder as it has been disabled.
    [ INFO  ] Checking for knife bootstrap configuration...
    [ INFO  ] Performing GPFS checks.
    [ INFO  ] Running environment checks
    [ INFO  ] Skipping license validation as no existing GPFS cluster detected.
    [ INFO  ] Checking pre-requisites for portability layer.
    [ INFO  ] GPFS precheck OK
    [ INFO  ] Performing Performance Monitoring checks.
    [ INFO  ] Running environment checks for Performance Monitoring
    [ INFO  ] Performing GUI checks.
    [ INFO  ] Performing FILE AUDIT LOGGING checks.
    [ INFO  ] Running environment checks for file  Audit logging
    [ INFO  ] Network check from admin node workr-136.netapp.com to all other nodes in the cluster passed
    [ INFO  ] Network check from admin node mastr-51.netapp.com to all other nodes in the cluster passed
    [ INFO  ] Network check from admin node mastr-53.netapp.com to all other nodes in the cluster passed
    [ INFO  ] The install toolkit will not configure call home as it is disabled. To enable call home, use the following CLI command: ./spectrumscale callhome enable
    [ INFO  ] Pre-check successful for install.
    [ INFO  ] Tip : ./spectrumscale install
  23. Configure os discos NSD.
    [root@mastr-51 cluster-test]# cat disk.1st
    %nsd: device=/dev/sdf
    nsd=nsd1
    servers=workr-136
    usage=dataAndMetadata
    failureGroup=1
    nsd=nsd2
    servers=workr-138
    failureGroup=1
  24. Crie os discos NSD.
    [root@mastr-51 cluster-test]# mmcrnsd -F disk.1st -v no
    mmcrnsd: Processing disk sdf
    mmcrnsd: Propagating the cluster configuration data to all
      affected nodes.  This is an asynchronous process.
  25. Verifique o estado do disco NSD.
    [root@mastr-51 cluster-test]# mmlsnsd
     File system   Disk name    NSD servers
     (free disk)   nsd1         workr-136.netapp.com
     (free disk)   nsd2         workr-138.netapp.com
  26. Crie o GPFS.
    [root@mastr-51 cluster-test]# mmcrfs gpfs1 -F disk.1st -B 1M -T /gpfs1
    The following disks of gpfs1 will be formatted on node workr-136.netapp.com:
        nsd1: size 3814912 MB
        nsd2: size 3814912 MB
    Formatting file system ...
    Disks up to size 33.12 TB can be added to storage pool system.
    Creating Inode File
    Creating Allocation Maps
    Creating Log Files
    Clearing Inode Allocation Map
    Clearing Block Allocation Map
    Formatting Allocation Map for storage pool system
    Completed creation of file system /dev/gpfs1.
    mmcrfs: Propagating the cluster configuration data to all
  27. Monte os GPFS.
    [root@mastr-51 cluster-test]# mmmount all -a
    Tue Oct  8 18:05:34 UTC 2019: mmmount: Mounting file systems ...
  28. Verifique e forneça as permissões necessárias para os GPFS.
    [root@mastr-51 cluster-test]# mmlsdisk gpfs1
    disk         driver   sector     failure holds    holds                            storage
    name         type       size       group metadata data  status        availability pool
    nsd1         nsd         512           1 Yes      Yes   ready         up           system
    nsd2         nsd         512           1 Yes      Yes   ready         up           system
    [root@mastr-51 cluster-test]# for i in 51 53 136 138  ; do ssh 10.63.150.$i "hostname; chmod 777 /gpfs1" ; done;
    mastr-51.netapp.com
    mastr-53.netapp.com
  29. Verifique os GPFS de leitura e gravação executando o dd comando.
    [root@mastr-51 cluster-test]# dd if=/dev/zero of=/gpfs1/testfile bs=1024M count=5
    5+0 records in
    5+0 records out
    5368709120 bytes (5.4 GB) copied, 8.3981 s, 639 MB/s
    [root@mastr-51 cluster-test]# for i in 51 53 136 138  ; do ssh 10.63.150.$i "hostname; ls -ltrh /gpfs1" ; done;
    mastr-51.netapp.com
    total 5.0G
    -rw-r--r-- 1 root root 5.0G Oct  8 18:10 testfile
    mastr-53.netapp.com
    total 5.0G
    total 5.0G
    total 5.0G
EXPORTAR GPFS para NFS
Para exportar GPFS para NFS, execute as seguintes etapas:
  1. Exporte os GPFS como NFS através do /etc/exports arquivo.
    [root@mastr-51 gpfs1]# cat /etc/exports
    /gpfs1        *(rw,fsid=745)
  2. Instale os pacotes de servidor NFS necessários.
    [root@mastr-51 ~]# yum install rpcbind
    Loaded plugins: priorities, product-id, search-disabled-repos, subscription-manager
    Resolving Dependencies
    --> Running transaction check
    ---> Package rpcbind.x86_64 0:0.2.0-47.el7 will be updated
    ---> Package rpcbind.x86_64 0:0.2.0-48.el7 will be an update
    --> Finished Dependency Resolution
    Dependencies Resolved
     Package                                               Arch                                                 Version                                                    Repository                                                        Size
    Updating:
     rpcbind                                               x86_64                                               0.2.0-48.el7                                               rhel-7-server-rpms                                                60 k
    Transaction Summary
    Upgrade  1 Package
    Total download size: 60 k
    Is this ok [y/d/N]: y
    Downloading packages:
    No Presto metadata available for rhel-7-server-rpms
    rpcbind-0.2.0-48.el7.x86_64.rpm        |  60 kB  00:00:00
    Running transaction test
    Transaction test succeeded
    Running transaction
      Updating   : rpcbind-0.2.0-48.el7.x86_64        1/2
      Cleanup    : rpcbind-0.2.0-47.el7.x86_64        2/2
      Verifying  : rpcbind-0.2.0-48.el7.x86_64        1/2
      Verifying  : rpcbind-0.2.0-47.el7.x86_64        2/2
    Updated:
    Complete!
    [root@mastr-51 ~]#
  3. Inicie o serviço NFS.
    [root@mastr-51 ~]# service nfs status
    Redirecting to /bin/systemctl status nfs.service
    ● nfs-server.service - NFS server and services
       Loaded: loaded (/usr/lib/systemd/system/nfs-server.service; disabled; vendor preset: disabled)
      Drop-In: /run/systemd/generator/nfs-server.service.d
               └─order-with-mounts.conf
       Active: inactive (dead)
    [root@mastr-51 ~]# service rpcbind start
    Redirecting to /bin/systemctl start rpcbind.service
    [root@mastr-51 ~]# service nfs start
    Redirecting to /bin/systemctl start nfs.service
       Active: active (exited) since Wed 2019-11-06 16:34:50 UTC; 2s ago
      Process: 24402 ExecStartPost=/bin/sh -c if systemctl -q is-active gssproxy; then systemctl reload gssproxy ; fi (code=exited, status=0/SUCCESS)
      Process: 24383 ExecStart=/usr/sbin/rpc.nfsd $RPCNFSDARGS (code=exited, status=0/SUCCESS)
      Process: 24379 ExecStartPre=/usr/sbin/exportfs -r (code=exited, status=0/SUCCESS)
     Main PID: 24383 (code=exited, status=0/SUCCESS)
       CGroup: /system.slice/nfs-server.service
    Nov 06 16:34:50 mastr-51.netapp.com systemd[1]: Starting NFS server and services...
    Nov 06 16:34:50 mastr-51.netapp.com systemd[1]: Started NFS server and services.
    [root@mastr-51 ~]#
  4. Liste os arquivos em GPFS para validar o cliente NFS.
    [root@mastr-51 gpfs1]# df -Th
    Filesystem                                 Type      Size  Used Avail Use% Mounted on
    /dev/mapper/rhel_stlrx300s6--22--irmc-root xfs        94G   55G   39G  59% /
    devtmpfs                                   devtmpfs   32G     0   32G   0% /dev
    tmpfs                                      tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                                      tmpfs      32G  3.3G   29G  11% /run
    tmpfs                                      tmpfs      32G     0   32G   0% /sys/fs/cgroup
    /dev/sda7                                  xfs       9.4G  210M  9.1G   3% /boot
    tmpfs                                      tmpfs     6.3G     0  6.3G   0% /run/user/10065
    tmpfs                                      tmpfs     6.3G     0  6.3G   0% /run/user/10068
    tmpfs                                      tmpfs     6.3G     0  6.3G   0% /run/user/10069
    10.63.150.213:/nc_volume3                  nfs4      380G  8.0M  380G   1% /mnt
    tmpfs                                      tmpfs     6.3G     0  6.3G   0% /run/user/0
    gpfs1                                      gpfs      7.3T  9.1G  7.3T   1% /gpfs1
    [root@mastr-51 ~]# cd /gpfs1
    [root@mastr-51 gpfs1]# ls
    catalog  ces  gpfs-ces  ha  testfile
    [root@mastr-51 gpfs1]# ls -ltrha
    total 5.1G
    dr-xr-xr-x   2 root root 8.0K Jan  1  1970 .snapshots
    dr-xr-xr-x. 30 root root 4.0K Oct  8 18:19 ..
    drwxr-xr-x   2 root root 4.0K Nov  5 20:02 gpfs-ces
    drwxr-xr-x   2 root root 4.0K Nov  5 20:04 ha
    drwxrwxrwx   5 root root 256K Nov  5 20:04 .
    drwxr-xr-x   4 root root 4.0K Nov  5 20:35 ces
Configurar o cliente NFS
Para configurar o cliente NFS, execute as seguintes etapas:
  1. Instalar pacotes no cliente NFS.
    [root@hdp2 ~]# yum install nfs-utils rpcbind
    Loaded plugins: product-id, search-disabled-repos, subscription-manager
    HDP-2.6-GPL-repo-4        | 2.9 kB  00:00:00
    HDP-2.6-repo-4        | 2.9 kB  00:00:00
    HDP-3.0-GPL-repo-2        | 2.9 kB  00:00:00
    HDP-3.0-repo-2        | 2.9 kB  00:00:00
    HDP-3.0-repo-3        | 2.9 kB  00:00:00
    HDP-3.1-repo-1        | 2.9 kB  00:00:00
    HDP-3.1-repo-51        | 2.9 kB  00:00:00
    HDP-UTILS-1.1.0.22-repo-1        | 2.9 kB  00:00:00
    HDP-UTILS-1.1.0.22-repo-2        | 2.9 kB  00:00:00
    HDP-UTILS-1.1.0.22-repo-3        | 2.9 kB  00:00:00
    HDP-UTILS-1.1.0.22-repo-4        | 2.9 kB  00:00:00
    HDP-UTILS-1.1.0.22-repo-51        | 2.9 kB  00:00:00
    ambari-2.7.3.0        | 2.9 kB  00:00:00
    epel/x86_64/metalink        |  13 kB  00:00:00
    epel        | 5.3 kB  00:00:00
    mysql-connectors-community        | 2.5 kB  00:00:00
    mysql-tools-community        | 2.5 kB  00:00:00
    mysql56-community        | 2.5 kB  00:00:00
    rhel-7-server-optional-rpms        | 3.2 kB  00:00:00
    rhel-7-server-rpms        | 3.5 kB  00:00:00
    (1/10): mysql-connectors-community/x86_64/primary_db                                           |  49 kB  00:00:00
    (2/10): mysql-tools-community/x86_64/primary_db                                                |  66 kB  00:00:00
    (3/10): epel/x86_64/group_gz        |  90 kB  00:00:00
    (4/10): mysql56-community/x86_64/primary_db                                                    | 241 kB  00:00:00
    (5/10): rhel-7-server-optional-rpms/7Server/x86_64/updateinfo                                  | 2.5 MB  00:00:00
    (6/10): rhel-7-server-rpms/7Server/x86_64/updateinfo                                           | 3.4 MB  00:00:00
    (7/10): rhel-7-server-optional-rpms/7Server/x86_64/primary_db                                  | 8.3 MB  00:00:00
    (8/10): rhel-7-server-rpms/7Server/x86_64/primary_db                                           |  62 MB  00:00:01
    (9/10): epel/x86_64/primary_db        | 6.9 MB  00:00:08
    (10/10): epel/x86_64/updateinfo        | 1.0 MB  00:00:13
    ---> Package nfs-utils.x86_64 1:1.3.0-0.61.el7 will be updated
    ---> Package nfs-utils.x86_64 1:1.3.0-0.65.el7 will be an update
    Updating:
     nfs-utils               x86_64               1:1.3.0-0.65.el7                 rhel-7-server-rpms               412 k
    Transaction Summary
    Upgrade  2 Packages
    Total download size: 472 k
    (1/2): rpcbind-0.2.0-48.el7.x86_64.rpm                                                         |  60 kB  00:00:00
    (2/2): nfs-utils-1.3.0-0.65.el7.x86_64.rpm                                                     | 412 kB  00:00:00
    Total        1.2 MB/s | 472 kB  00:00:00
    Running transaction
      Updating   : rpcbind-0.2.0-48.el7.x86_64        1/4
      Updating   : 1:nfs-utils-1.3.0-0.65.el7.x86_64        2/4
      Cleanup    : 1:nfs-utils-1.3.0-0.61.el7.x86_64        3/4
      Cleanup    : rpcbind-0.2.0-47.el7.x86_64        4/4
      Verifying  : 1:nfs-utils-1.3.0-0.65.el7.x86_64        1/4
      Verifying  : rpcbind-0.2.0-48.el7.x86_64        2/4
      Verifying  : rpcbind-0.2.0-47.el7.x86_64        3/4
      Verifying  : 1:nfs-utils-1.3.0-0.61.el7.x86_64        4/4
    Updated:
      nfs-utils.x86_64 1:1.3.0-0.65.el7                           rpcbind.x86_64 0:0.2.0-48.el7
    Complete!
    [root@hdp2 ~]#
  2. Inicie os serviços do cliente NFS.
    [root@hdp2 ~]# service rpcbind start
     [root@hdp2 ~]#
  3. Montar os GPFS por meio do protocolo NFS no cliente NFS.
    [root@hdp2 ~]# mkdir /gpfstest
    [root@hdp2 ~]# mount 10.63.150.51:/gpfs1 /gpfstest
    [root@hdp2 ~]# df -h
    Filesystem                            Size  Used Avail Use% Mounted on
    /dev/mapper/rhel_stlrx300s6--22-root  1.1T  113G  981G  11% /
    devtmpfs                              126G     0  126G   0% /dev
    tmpfs                                 126G   16K  126G   1% /dev/shm
    tmpfs                                 126G  510M  126G   1% /run
    tmpfs                                 126G     0  126G   0% /sys/fs/cgroup
    /dev/sdd2                             197M  191M  6.6M  97% /boot
    tmpfs                                  26G     0   26G   0% /run/user/0
    10.63.150.213:/nc_volume2              95G  5.4G   90G   6% /mnt
    10.63.150.51:/gpfs1                   7.3T  9.1G  7.3T   1% /gpfstest
    [root@hdp2 ~]#
  4. Valide a lista de ARQUIVOS GPFS na pasta montada em NFS.
    [root@hdp2 ~]# cd /gpfstest/
    [root@hdp2 gpfstest]# ls
    [root@hdp2 gpfstest]# ls -l
    total 5242882
    drwxr-xr-x 4 root root       4096 Nov  5 15:35 ces
    drwxr-xr-x 2 root root       4096 Nov  5 15:02 gpfs-ces
    drwxr-xr-x 2 root root       4096 Nov  5 15:04 ha
    -rw-r--r-- 1 root root 5368709120 Oct  8 14:10 testfile
  5. Mova os dados do NFS GPFS- exportado para o NFS NetApp usando o XCP.
    [root@hdp2 linux]# ./xcp copy -parallel 20 10.63.150.51:/gpfs1 10.63.150.213:/nc_volume2/
    XCP 1.4-17914d6; (c) 2019 NetApp, Inc.; Licensed to Karthikeyan Nagalingam [NetApp Inc] until Tue Nov  5 12:39:36 2019
    xcp: WARNING: your license will expire in less than one week! You can renew your license at https://xcp.netapp.com
    xcp: open or create catalog 'xcp': Creating new catalog in '10.63.150.51:/gpfs1/catalog'
    xcp: WARNING: No index name has been specified, creating one with name: autoname_copy_2019-11-11_12.14.07.805223
    xcp: mount '10.63.150.51:/gpfs1': WARNING: This NFS server only supports 1-second timestamp granularity. This may cause sync to fail because changes will often be undetectable.
     34 scanned, 32 copied, 32 indexed, 1 giant, 301 MiB in (59.5 MiB/s), 784 KiB out (155 KiB/s), 6s
     34 scanned, 32 copied, 32 indexed, 1 giant, 725 MiB in (84.6 MiB/s), 1.77 MiB out (206 KiB/s), 11s
     34 scanned, 32 copied, 32 indexed, 1 giant, 1.17 GiB in (94.2 MiB/s), 2.90 MiB out (229 KiB/s), 16s
     34 scanned, 32 copied, 32 indexed, 1 giant, 1.56 GiB in (79.8 MiB/s), 3.85 MiB out (194 KiB/s), 21s
     34 scanned, 32 copied, 32 indexed, 1 giant, 1.95 GiB in (78.4 MiB/s), 4.80 MiB out (191 KiB/s), 26s
     34 scanned, 32 copied, 32 indexed, 1 giant, 2.35 GiB in (80.4 MiB/s), 5.77 MiB out (196 KiB/s), 31s
     34 scanned, 32 copied, 32 indexed, 1 giant, 2.79 GiB in (89.6 MiB/s), 6.84 MiB out (218 KiB/s), 36s
     34 scanned, 32 copied, 32 indexed, 1 giant, 3.16 GiB in (75.3 MiB/s), 7.73 MiB out (183 KiB/s), 41s
     34 scanned, 32 copied, 32 indexed, 1 giant, 3.53 GiB in (75.4 MiB/s), 8.64 MiB out (183 KiB/s), 46s
     34 scanned, 32 copied, 32 indexed, 1 giant, 4.00 GiB in (94.4 MiB/s), 9.77 MiB out (230 KiB/s), 51s
     34 scanned, 32 copied, 32 indexed, 1 giant, 4.46 GiB in (94.3 MiB/s), 10.9 MiB out (229 KiB/s), 56s
     34 scanned, 32 copied, 32 indexed, 1 giant, 4.86 GiB in (80.2 MiB/s), 11.9 MiB out (195 KiB/s), 1m1s
    Sending statistics...
    34 scanned, 33 copied, 34 indexed, 1 giant, 5.01 GiB in (81.8 MiB/s), 12.3 MiB out (201 KiB/s), 1m2s.
    [root@hdp2 linux]#
  6. Valide os ARQUIVOS GPFS no cliente NFS.
    [root@hdp2 mnt]# df -Th
    /dev/mapper/rhel_stlrx300s6--22-root xfs       1.1T  113G  981G  11% /
    devtmpfs                             devtmpfs  126G     0  126G   0% /dev
    tmpfs                                tmpfs     126G   16K  126G   1% /dev/shm
    tmpfs                                tmpfs     126G  518M  126G   1% /run
    tmpfs                                tmpfs     126G     0  126G   0% /sys/fs/cgroup
    /dev/sdd2                            xfs       197M  191M  6.6M  97% /boot
    tmpfs                                tmpfs      26G     0   26G   0% /run/user/0
    10.63.150.213:/nc_volume2            nfs4       95G  5.4G   90G   6% /mnt
    10.63.150.51:/gpfs1                  nfs4      7.3T  9.1G  7.3T   1% /gpfstest
    [root@hdp2 mnt]#
    [root@hdp2 mnt]# ls -ltrha
    total 128K
    dr-xr-xr-x   2 root        root                4.0K Dec 31  1969 .snapshots
    drwxrwxrwx   2 root        root                4.0K Feb 14  2018 data
    drwxrwxrwx   3 root        root                4.0K Feb 14  2018 wcresult
    drwxrwxrwx   3 root        root                4.0K Feb 14  2018 wcresult1
    drwxrwxrwx   2 root        root                4.0K Feb 14  2018 wcresult2
    drwxrwxrwx   2 root        root                4.0K Feb 16  2018 wcresult3
    -rw-r--r--   1 root        root                2.8K Feb 20  2018 READMEdemo
    drwxrwxrwx   3 root        root                4.0K Jun 28 13:38 scantg
    drwxrwxrwx   3 root        root                4.0K Jun 28 13:39 scancopyFromLocal
    -rw-r--r--   1 hdfs        hadoop              1.2K Jul  3 19:28 f3
    -rw-r--r--   1 hdfs        hadoop              1.2K Jul  3 19:28 README
    -rw-r--r--   1 hdfs        hadoop              1.2K Jul  3 19:28 f9
    -rw-r--r--   1 hdfs        hadoop              1.2K Jul  3 19:28 f6
    -rw-r--r--   1 hdfs        hadoop              1.2K Jul  3 19:28 f5
    -rw-r--r--   1 hdfs        hadoop              1.2K Jul  3 19:30 f4
    -rw-r--r--   1 hdfs        hadoop              1.2K Jul  3 19:30 f8
    -rw-r--r--   1 hdfs        hadoop              1.2K Jul  3 19:30 f2
    -rw-r--r--   1 hdfs        hadoop              1.2K Jul  3 19:30 f7
    drwxrwxrwx   2 root        root                4.0K Jul  9 11:14 test
    drwxrwxrwx   3 root        root                4.0K Jul 10 16:35 warehouse
    drwxr-xr-x   3       10061 tester1             4.0K Jul 15 14:40 sdd1
    drwxrwxrwx   3 testeruser1 hadoopkerberosgroup 4.0K Aug 20 17:00 kermkdir
    -rw-r--r--   1 testeruser1 hadoopkerberosgroup    0 Aug 21 14:20 newfile
    drwxrwxrwx   2 testeruser1 hadoopkerberosgroup 4.0K Aug 22 10:13 teragen1copy_3
    drwxrwxrwx   2 testeruser1 hadoopkerberosgroup 4.0K Aug 22 10:33 teragen2copy_1
    -rw-rwxr--   1 root        hdfs                1.2K Sep 19 16:38 R1
    drwx------   3 root        root                4.0K Sep 20 17:28 user
    -rw-r--r--   1 root        root                5.0G Oct  8 14:10 testfile
    drwxr-xr-x   2 root        root                4.0K Nov  5 15:02 gpfs-ces
    drwxr-xr-x   2 root        root                4.0K Nov  5 15:04 ha
    drwxr-xr-x   4 root        root                4.0K Nov  5 15:35 ces
    dr-xr-xr-x. 26 root        root                4.0K Nov  6 11:40 ..
    drwxrwxrwx  21 root        root                4.0K Nov 11 12:14 .
    drwxrwxrwx   7 nobody      nobody              4.0K Nov 11 12:14 catalog
    [root@hdp2 mnt]#
