Limpando reservas persistentes SCSI-3
Colaboradores netapp-aherbin
Se você tiver um cluster do Windows, precisará remover reservas SCSI-3 para o disco de quorum, mesmo que todos os hosts em cluster estejam offline.
Se você tentar rotular o LUN de origem como um disco estranho, a seguinte mensagem de erro será exibida:
 Error: command failed: The specified foreign disk has SCSI persistent reservations. Disk serial number: "6006016021402700787BAC217B44E411". Clear the reservation using the "storage disk remove-reservation" command before creating the import relationship.
Você pode remover reservas SCSI-3 para o disco de quorum na controladora NetApp usando o `storage disk remove-reservation` comando:
storage disk remove-reservation –disk disk_name
Aqui está um snippet mostrando esse erro e a correção para ele:
cluster-4b::*> lun offline -vserver fli_cluster -path /vol/fli_volume/cluster_1
cluster-4b::*> lun import create -vserver fli_cluster -path /vol/fli_volume/cluster_1 -foreign-disk 6006016021402700787BAC217B44E411
Error: command failed: The specified foreign disk is not marked as foreign. Disk serial number: "6006016021402700787BAC217B44E411".
cluster-4b::*> sto disk show -disk DGC-1.6 -fields serial-number,is-foreign
 (storage disk show)
disk is-foreign serial-number
DGC-1.6 true 6006016021402700787BAC217B44E411
cluster-4b::*> storage disk remove-reservation -disk DGC-1.6
cluster-4b::*> lun online -vserver fli_cluster -path /vol/fli_volume/cluster_1
cluster-4b::*> lun import show
vserver foreign-disk path operation admin operational percent in progress state state complete
fli_cluster 6006016021402700787BAC217B44E411 /vol/fli_volume/cluster_1 import stopped stopped 0
cluster-4b::*> lun import start -vserver fli_cluster -path /vol/fli_volume/cluster_1
fli_cluster 6006016021402700787BAC217B44E411 /vol/fli_volume/cluster_1 import started in_progress 7
