Configure as portas para migração para os switches de cluster Cisco Nexus 3132Q-V
Colaboradores netapp-yvonneo netapp-jsnyder
Configure as portas para migração de um cluster sem switch de dois nós para um cluster com switch de dois nós usando os switches de cluster Cisco Nexus 3132Q-V.
Passos
  1. Nos switches Nexus 3132Q-V C1 e C2, desative todas as portas voltadas para o nó C1 e C2, mas não desative as portas ISL.
    Mostrar exemplo
    O exemplo a seguir mostra as portas de 1 a 30 sendo desativadas nos switches de cluster Nexus 3132Q-V C1 e C2 usando uma configuração compatível com RCF NX3132_RCF_v1.1_24p10g_26p40g.txt:
    C1# copy running-config startup-config
    [########################################] 100%
    Copy complete.
    C1# configure
    C1(config)# int e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7-30
    C1(config-if-range)# shutdown
    C1(config-if-range)# exit
    C1(config)# exit
    C2# copy running-config startup-config
    Copy complete.
    C2# configure
    C2(config)# int e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7-30
    C2(config-if-range)# shutdown
    C2(config-if-range)# exit
    C2(config)# exit
  2. Conecte as portas 1/31 e 1/32 em C1 às mesmas portas em C2 usando cabeamento compatível.
  3. Verifique se as portas ISL estão operacionais em C1 e C2:
    show port-channel summary
    Mostrar exemplo
    C1# show port-channel summary
    Flags: D - Down         P - Up in port-channel (members)
           I - Individual   H - Hot-standby (LACP only)
           s - Suspended    r - Module-removed
           S - Switched     R - Routed
           U - Up (port-channel)
           M - Not in use. Min-links not met
    Group Port-        Type   Protocol  Member Ports
          Channel
    1     Po1(SU)      Eth    LACP      Eth1/31(P)   Eth1/32(P)
    C2# show port-channel summary
          Channel
  4. Exiba a lista de dispositivos vizinhos no switch:
    show cdp neighbors
    Mostrar exemplo
    C1# show cdp neighbors
    Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                      S - Switch, H - Host, I - IGMP, r - Repeater,
                      V - VoIP-Phone, D - Remotely-Managed-Device,
                      s - Supports-STP-Dispute
    Device-ID          Local Intrfce  Hldtme Capability  Platform      Port ID
    C2                 Eth1/31        174    R S I s     N3K-C3132Q-V  Eth1/31
    C2                 Eth1/32        174    R S I s     N3K-C3132Q-V  Eth1/32
    Total entries displayed: 2
    C2# show cdp neighbors
    C1                 Eth1/31        178    R S I s     N3K-C3132Q-V  Eth1/31
    C1                 Eth1/32        178    R S I s     N3K-C3132Q-V  Eth1/32
  5. Exiba a conectividade da porta do cluster em cada nó:
    network device-discovery show
    Mostrar exemplo
    O exemplo a seguir mostra uma configuração de cluster sem switch com dois nós.
    cluster::*> network device-discovery show
                Local  Discovered
    Node        Port   Device              Interface        Platform
    n1         /cdp
                e4a    n2                  e4a              FAS9000
                e4e    n2                  e4e              FAS9000
    n2         /cdp
                e4a    n1                  e4a              FAS9000
                e4e    n1                  e4e              FAS9000
  6. Migre a interface clus1 para a porta física que hospeda clus2:
    network interface migrate
    Execute este comando a partir de cada nó local.
    Mostrar exemplo
    cluster::*> network interface migrate -vserver Cluster -lif n1_clus1 -source-node n1
    -destination-node n1 -destination-port e4e
    cluster::*> network interface migrate -vserver Cluster -lif n2_clus1 -source-node n2
    -destination-node n2 -destination-port e4e
  7. Verifique a migração das interfaces do cluster:
    network interface show
    Mostrar exemplo
    cluster::*> network interface show -role cluster
     (network interface show)
                Logical    Status     Network            Current       Current Is
    Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
    Cluster
                n1_clus1   up/up      10.10.0.1/24       n1            e4e     false
                n1_clus2   up/up      10.10.0.2/24       n1            e4e     true
                n2_clus1   up/up      10.10.0.3/24       n2            e4e     false
                n2_clus2   up/up      10.10.0.4/24       n2            e4e     true
    4 entries were displayed.
  8. Desative as portas do cluster clus1 LIF em ambos os nós:
    network port modify
    cluster::*> network port modify -node n1 -port e4a -up-admin false
    cluster::*> network port modify -node n2 -port e4a -up-admin false
  9. Verifique a conectividade das interfaces do cluster remoto:
ONTAP 9.9.1 e posterior
Você pode usar o network interface check cluster-connectivity Comando para iniciar uma verificação de acessibilidade para conectividade do cluster e, em seguida, exibir os detalhes:
network interface check cluster-connectivity start`e `network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTA: Aguarde alguns segundos antes de executar o comando show para exibir os detalhes.
cluster1::*> network interface check cluster-connectivity show
                                  Source          Destination       Packet
Node   Date                       LIF             LIF               Loss
n1
       3/5/2022 19:21:18 -06:00   n1_clus2        n2_clus1      none
       3/5/2022 19:21:20 -06:00   n1_clus2        n2_clus2      none
n2
       3/5/2022 19:21:18 -06:00   n2_clus2        n1_clus1      none
       3/5/2022 19:21:20 -06:00   n2_clus2        n1_clus2      none
Todas as versões do ONTAP
Para todas as versões do ONTAP , você também pode usar o cluster ping-cluster -node <name> comando para verificar a conectividade:
cluster::*> cluster ping-cluster -node n1
Host is n1
Getting addresses from network interface table...
Cluster n1_clus1 n1		e4a	10.10.0.1
Cluster n1_clus2 n1		e4e	10.10.0.2
Cluster n2_clus1 n2		e4a	10.10.0.3
Cluster n2_clus2 n2		e4e	10.10.0.4
Local = 10.10.0.1 10.10.0.2
Remote = 10.10.0.3 10.10.0.4
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 1500 byte MTU on 32 path(s):
    Local 10.10.0.1 to Remote 10.10.0.3
    Local 10.10.0.1 to Remote 10.10.0.4
    Local 10.10.0.2 to Remote 10.10.0.3
    Local 10.10.0.2 to Remote 10.10.0.4
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
1 paths up, 0 paths down (tcp check)
1 paths up, 0 paths down (ucp check)
  1. Desconecte o cabo de e4a no nó n1.
    Você pode consultar a configuração em execução e conectar a primeira porta 40 GbE no switch C1 (porta 1/7 neste exemplo) à e4a no n1 usando cabos compatíveis no Nexus 3132Q-V.
    Observação Ao reconectar qualquer cabo a um novo switch de cluster Cisco, os cabos utilizados devem ser de fibra óptica ou cabos suportados pela Cisco.
  2. Desconecte o cabo do e4a no nó n2.
    Você pode consultar a configuração em execução e conectar e4a à próxima porta 40 GbE disponível em C1, porta 1/8, usando cabos compatíveis.
  3. Habilite todas as portas voltadas para o nó em C1.
    Mostrar exemplo
    O exemplo a seguir mostra as portas de 1 a 30 sendo habilitadas nos switches de cluster Nexus 3132Q-V C1 e C2 usando a configuração suportada no RCF NX3132_RCF_v1.1_24p10g_26p40g.txt:
    C1# configure
    C1(config-if-range)# no shutdown
    C1(config)# exit
  4. Ative a primeira porta do cluster, e4a, em cada nó:
    network port modify
    Mostrar exemplo
    cluster::*> network port modify -node n1 -port e4a -up-admin true
    cluster::*> network port modify -node n2 -port e4a -up-admin true
  5. Verifique se os clusters estão ativos em ambos os nós:
    network port show
    Mostrar exemplo
    cluster::*> network port show -role cluster
      (network port show)
    Node: n1
        Ignore
                                                      Speed(Mbps) Health   Health
    Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
    e4a       Cluster      Cluster          up   9000 auto/40000  -        -
    e4e       Cluster      Cluster          up   9000 auto/40000  -        -
    Node: n2
        Ignore
  6. Para cada nó, reverta todas as LIFs de interconexão de cluster migradas:
    network interface revert
    Mostrar exemplo
    O exemplo a seguir mostra as LIFs migradas sendo revertidas para suas portas de origem.
    cluster::*> network interface revert -vserver Cluster -lif n1_clus1
    cluster::*> network interface revert -vserver Cluster -lif n2_clus1
  7. Verifique se todas as portas de interconexão de cluster agora foram revertidas para suas portas originais:
    A Is Home coluna deve exibir um valor de true para todas as portas listadas na Current Port coluna. Se o valor exibido for false, a porta não foi revertida.
    Mostrar exemplo
    Cluster
                n1_clus1   up/up      10.10.0.1/24       n1            e4a     true
                n2_clus1   up/up      10.10.0.3/24       n2            e4a     true
  8. Exiba a conectividade da porta do cluster em cada nó:
    Mostrar exemplo
                Local  Discovered
    n1         /cdp
                e4a    C1                  Ethernet1/7      N3K-C3132Q-V
                e4e    n2                  e4e              FAS9000
    n2         /cdp
                e4a    C1                  Ethernet1/8      N3K-C3132Q-V
                e4e    n1                  e4e              FAS9000
  9. No console de cada nó, migre o clus2 para a porta e4a:
    Mostrar exemplo
    cluster::*> network interface migrate -vserver Cluster -lif n1_clus2 -source-node n1
    -destination-node n1 -destination-port e4a
    cluster::*> network interface migrate -vserver Cluster -lif n2_clus2 -source-node n2
    -destination-node n2 -destination-port e4a
  10. Desative as portas do cluster clus2 LIF em ambos os nós:
    network port modify
    O exemplo a seguir mostra as portas especificadas sendo desativadas em ambos os nós:
    cluster::*> network port modify -node n1 -port e4e -up-admin false
    cluster::*> network port modify -node n2 -port e4e -up-admin false
  11. Verifique o status do LIF do cluster:
    Mostrar exemplo
    Cluster
                n1_clus2   up/up      10.10.0.2/24       n1            e4a     false
                n2_clus2   up/up      10.10.0.4/24       n2            e4a     false
  12. Desconecte o cabo do e4e no nó n1.
    Você pode consultar a configuração em execução e conectar a primeira porta 40 GbE no switch C2 (porta 1/7 neste exemplo) à e4e em n1 usando cabeamento compatível no Nexus 3132Q-V.
  13. Desconecte o cabo do e4e no nó n2.
    Você pode consultar a configuração em execução e conectar e4e à próxima porta 40 GbE disponível em C2, porta 1/8, usando cabos compatíveis.
  14. Habilite todas as portas voltadas para o nó no C2.
    Mostrar exemplo
    O exemplo a seguir mostra as portas de 1 a 30 sendo habilitadas nos switches de cluster Nexus 3132Q-V C1 e C2 usando uma configuração compatível com RCF NX3132_RCF_v1.1_24p10g_26p40g.txt:
    C2# configure
    C2(config-if-range)# no shutdown
    C2(config)# exit
  15. Ative a segunda porta do cluster, e4e, em cada nó:
    network port modify
    O exemplo a seguir mostra as portas especificadas sendo ativadas:
    cluster::*> network port modify -node n1 -port e4e -up-admin true
    cluster::*> network port modify -node n2 -port e4e -up-admin true
  16. Para cada nó, reverta todas as LIFs de interconexão de cluster migradas:
    cluster::*> network interface revert -vserver Cluster -lif n1_clus2
    cluster::*> network interface revert -vserver Cluster -lif n2_clus2
  17. Verifique se todas as portas de interconexão de cluster agora foram revertidas para suas portas originais:
    Mostrar exemplo
    Cluster
  18. Verifique se todas as portas de interconexão de cluster estão no up estado.
    Mostrar exemplo
      (network port show)
    Node: n1
        Ignore
    Node: n2
        Ignore
O que vem a seguir?
Depois de configurar as portas do seu switch, você pode "Conclua sua migração".
