smis crsp
O smis crsp comando descreve os subperfis registrados pelo CIM suportados pelo Fornecedor SMI-S do NetApp, incluindo os subperfis do Fornecedor SMI-S. do NetApp.
Sintaxe
smis crsp
[-t {http | https}]
Localização
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Nível de privilégio
Um utilizador com um nome de utilizador e uma palavra-passe válidos
Parâmetros
[-t {http | https}]Protocolo a ser usado: HTTPS (padrão) ou HTTP
Exemplo
O smis crsp comando e sua saída abreviada:
smis crsp PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.4.0" PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.5.0" PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.6.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.4.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.5.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.6.0" PG_RegisteredSubProfile.InstanceID="SNIA:Object Manager Adapter:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:iSCSI Target Ports:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:iSCSI Target Ports:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Software:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Multiple Computer System:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Access Points:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Target Port:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Masking and Mapping:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Masking and Mapping:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Server Performance:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Server Performance:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Physical Package:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Physical Package:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Health:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FileSystem:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Storage:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export Manipulation:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File System Manipulation:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Filesystem Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Server Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FileSystem Quotas:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Job Control:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Job Control:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Location:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:NAS Network Port:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Replication Services:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Replication Services:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Capacity Utilization:1.4.0"
