Scripts de exemplo para suportar bancos de dados ASM sem ASMLib
Os scripts de exemplo estão disponíveis no diretório plugins/examples/noasmlib do diretório de instalação do SnapManager for Oracle.
asmmain.sh
#!/bin/bash
griduser=grid
gridgroup=oinstall
# Run the script which takes the disklist from the asmcmd
# use appropriate user , here grid user is being used to run
# asmcmd command.
su -c "plugins/noasmlib/asmdiskquery.sh" -s /bin/sh grid
cat /home/grid/disklist
# Construct the final file as .bak file with propre inputs
awk -v guser=$griduser -v ggroup=$gridgroup '/^\/dev\/mapper/ { print "chown -R "guser":"ggroup" "$1; print "chmod 777 " $1; }' /home/grid/disklist > /etc/initasmdisks.bak
# move the bak file to the actual file.
mv /etc/initasmdisks.bak /etc/initasmdisks
# Set full full permission for this file to be called while rebooting and restore
chmod 777 /etc/initasmdisks
# If the /etc/initasmdisks needs to be updated in all the RAC nodes
# or /etc/initasmdisks script has to be executed in the RAC nodes, then the following
# section needs to be uncommented and used.
# Note: To do scp or running scripts in remote RAC node via ssh, it needs password less login
# for root user with ssh keys shared between the two nodes.
# The following 2 lines are used for updating the file in the RAC nodes:
# scp /etc/initasmdisks root@racnode1:/etc/initasmdisks
# scp /etc/initasmdisks root@racnode2:/etc/initasmdisks
# In order to execute the /etc/initasmdisks in other RAC nodes
# The following must be added to the master RAC node /etc/initasmdisks file
# from the asmmain.sh script itself. The above scp transfer will make sure
# the permissions and mode for the disk list contents are transferred to the other RAC nodes
# so now appending any command in the /etc/initasmsdisks will be retained only in the master RAC node.
# The following lines will add entries to the /etc/initasmsdisks file in master RAC node only. When this script is executed
# master RAC node, /etc/initasmdisks in all the RAC nodes will be executed.
# echo 'ssh racnode1 /etc/initasmdisks' >> /etc/initasmdisks
# echo 'ssh racnode2 /etc/initasmdisks' >> /etc/initasmdisks
asmquerydisk.sh
#!/bin/bash export ORACLE_BASE=/u01/app/oracle export ORACLE_HOME=/u01/app/grid/product/11.2.0.3/grid export ORACLE_SID=+ASM export PATH=$ORACLE_HOME/bin:$PATH # Get the Disk List and save this in a file called dglist. asmcmd lsdsk > /home/grid/disklist # In oracle 10g the above used command 'asmcmd' is not available so use SQL # query can be used to take the disk list. Need to uncomment the following # line and comment the above incase oracle 10g is being in use. # The disk_list.sql script is availbe in this noasmlib examples folder itself # which can be modified as per customer needs. # sqlplus "/as sysdba" @/home/grid/disk_list.sql > /home/grid/disklist
disk_list.sql
# su - oracle -bash-4.1$ cat disk_list.sql select path from v$asm_disk; exit -bash-4.1$
