O comando smo clone split
Você pode executar o comando clone split para dividir um clone. O clone dividido torna-se independente do clone original. O SnapManager gera um novo perfil após a operação de divisão de clones e você pode usar esse perfil para gerenciar o clone dividido.
Sintaxe
smo clone split
-profile clone-profile
\[-host hostname\]
\{-label clone-label | -id clone-id\} \[-split-label split-operation_label\]
\[-comment comment\]
-new-profile new-profile-name \[-profile-password new-profile_password\]
-repository -dbname repo_service_name
-host repo_host
-port repo_port
-login -username repo_username
-database -dbname db_dbname
-host db_host \[-sid db_sid\] \[-login -username db_username -password db_password
-port db_port\]
\[-rman \{\{-controlfile \| \{-login -username rman_username
-password rman_password\} -tnsname rman_tnsname\}\}\]
-osaccount osaccount
-osgroup osgroup
\[-retain
\[-hourly \[-count n\] \[-duration m\]\]
\[-daily \[-count n\] \[-duration m\]\]
\[-weekly \[-count n\] \[-duration m\]\]
\[-monthly \[-count n\] \[-duration m\]\] \]
\[-profile-comment profile-comment\]
\[-snapname-pattern pattern\]
\[-protect \[-protection-policy policy_name\]\] \| \[-noprotect\]\]
\[-summary-notification
\[-notification
\[-success -email email_address1,email_address2
-subject subject-pattern\]
\[failure -email email_address1,email_address2
-subject subject-pattern\] \]
[-separate-archivelog-backups
-retain-archivelog-backups
-hours hours |
-days days |
-weeks weeks |
-months months
[-protect \[-protection-policy policy_name \| -noprotect]
[-include-with-online-backups \| -no-include-with-online-backups]]
[-dump]
\[-quiet \| -verbose\]
Parâmetros
-perfil clone-profile
Especifica o nome do perfil a partir do qual o clone é criado.
-host hostname
Especifica o nome do host no qual o clone existe.
-label clone-label
Especifica o nome do rótulo gerado pela operação clone.
-id clone-id
Especifica o ID exclusivo gerado pela operação clone.
-new-profile new-profile_name
Especifica o novo nome de perfil que o SnapManager irá gerar após uma operação de divisão bem-sucedida.
Especifica a senha do perfil.
-repositório
Especifica os detalhes do banco de dados para o repositório.
Especifica o nome do banco de dados que armazena o repositório. Você pode usar o nome global ou o identificador do sistema.
-host repo_host
Especifica o nome ou endereço IP do computador host no qual o banco de dados do repositório reside.
-port repo_port
Especifica o número da porta TCP (Transmission Control Protocol) usada para acessar o host no qual o banco de dados do repositório reside.
-login
Especifica os detalhes de login do repositório. Isso é opcional. Se não for especificado, o SnapManager padrão será o modo de conexão de autenticação do sistema operacional.
Especifica o nome de usuário necessário para acessar o host no qual o banco de dados do repositório reside.
-banco de dados
Especifica os detalhes do banco de dados que será feito backup, restaurado ou clonado.
-dbname db_dbname
Especifica o nome do banco de dados descrito pelo perfil. Você pode usar o nome global ou o identificador do sistema.
-host db_host
Especifica o nome ou endereço IP do computador host no qual o banco de dados reside.
-sid db_sid
Especifica o identificador do sistema do banco de dados descrito pelo perfil. Por padrão, o SnapManager usa o nome do banco de dados como o identificador do sistema. Se o identificador do sistema for diferente do nome do banco de dados, você deve especificá-lo usando a opção -sid.
Por exemplo, se você estiver usando o RAC (Oracle Real Application clusters), especifique o identificador de sistema da instância RAC no nó RAC a partir do qual o SnapManager é executado.
-login
Especifica os detalhes de login do banco de dados.
Especifica o nome de usuário necessário para acessar o banco de dados descrito pelo perfil.
Especifica a senha necessária para acessar o banco de dados descrito pelo perfil.
-rman
Especifica os detalhes que o SnapManager usa para catalogar backups com o Oracle Recovery Manager (RMAN).
-controlfile
Especifica os arquivos de controle de banco de dados de destino como o repositório RMAN em vez de um catálogo.
-login
Especifica os detalhes de login do RMAN.
Especifica a senha usada para fazer login no catálogo RMAN.
Especifica o nome de usuário usado para fazer login no catálogo RMAN.
-tnsname tnsname
Especifica o nome da conexão tnsname (isso é definido no arquivo tsname.ora).
-osconta osconta
Especifica o nome da conta de usuário do banco de dados Oracle. O SnapManager usa essa conta para executar as operações Oracle, como inicialização e desligamento. Normalmente, é o usuário que possui o software Oracle no host, por exemplo, oracle.
-osgrupo osgrupo
Especifica o nome do grupo de banco de dados Oracle associado à conta oracle.
As variáveis -osaccount e -osgroup são necessárias para UNIX, mas não são permitidas para bancos de dados em execução no Windows. -
-reter [-hora [-count n] [-duração m]] [-diária [-count n] [-duração m]] [-semanal [-count n] [-duração m]] [-mensal [-count n] [-duração m]]
Especifica a política de retenção para um backup.
Para cada classe de retenção, a contagem de retenção ou a duração de retenção podem ser especificadas. A duração é em unidades da classe (por exemplo, horas por hora, dias por dia). Por exemplo, se você especificar apenas uma duração de retenção de 7 para backups diários, o SnapManager não limitará o número de backups diários para o perfil (porque a contagem de retenção é 0), mas o SnapManager excluirá automaticamente backups diários criados há mais de 7 dias.
Especifica o comentário para um perfil descrevendo o domínio do perfil.
-snapname-padrão padrão
Especifica o padrão de nomenclatura para cópias Snapshot. Você também pode incluir texto personalizado, por exemplo, HAOPS para operações altamente disponíveis, em todos os nomes de cópia Snapshot. Você pode alterar o padrão de nomenclatura da cópia Snapshot ao criar um perfil ou após o perfil ser criado. O padrão atualizado se aplica apenas a cópias Snapshot que ainda não foram criadas. As cópias snapshot que existem mantêm o padrão Snapname anterior. Você pode usar várias variáveis no texto padrão.
-protect -protection-policy_name
Especifica se o backup deve ser protegido para o storage secundário.
Se -protect for especificado sem -protection-policy, o conjunto de dados não terá uma política de proteção. Se -protect for especificado e -protection-policy não for definido quando o perfil for criado, ele poderá ser definido mais tarde pelo comando smo profile update ou definido pelo administrador de armazenamento usando o console do Protection Manager. -
Especifica os detalhes para configurar a notificação de e-mail de resumo para vários perfis em um banco de dados de repositório. O SnapManager gera este e-mail.
-notificação
Especifica os detalhes para configurar a notificação de e-mail para o novo perfil. O SnapManager gera este e-mail. A notificação por e-mail permite que o administrador do banco de dados receba e-mails sobre o status com êxito ou com falha da operação do banco de dados que é realizada usando esse perfil.
-sucesso
Especifica que a notificação por e-mail está ativada para um perfil para quando a operação SnapManager for bem-sucedida.
endereço de e-mail 1 endereço de e-mail 2*
Especifica o endereço de e-mail do destinatário.
-sujeito sujeito-padrão
Especifica o assunto do e-mail.
-falha
Especifica que a notificação por e-mail está ativada para um perfil para quando a operação SnapManager falha.
Especifica que o backup do log de arquivamento é separado do backup do arquivo de dados. Este é um parâmetro opcional, que você pode fornecer ao criar o perfil. Depois que os backups são separados usando essa opção, você pode criar backup somente de datafiles ou backup somente de logs de arquivamento.
-retent-archivelog-backups -horas | -daydays | -weeksweeks| -monthsmonths
Especifica que os backups de log de arquivamento são mantidos com base na duração de retenção de log de arquivamento (hora, dia, semanal ou mensal).
* proteger [-protection-policy_name] | -noprotect*
Especifica que os arquivos de log de arquivamento estão protegidos com base na política de proteção de log de arquivamento.
Especifica que os arquivos de log de arquivo não são protegidos usando a opção -noprotect.
-include-with-online-backups | -no-include-with-online-backups
Especifica que o backup do log de arquivamento está incluído junto com o backup do banco de dados on-line.
Especifica que os backups de log de arquivamento não são incluídos juntamente com o backup de banco de dados on-line.
-dump
Especifica que os arquivos de despejo não são coletados após a operação de criação de perfil bem-sucedida.
-silencioso
Exibe apenas mensagens de erro no console. A configuração padrão exibe mensagens de erro e aviso.
-verbose
Exibe mensagens de erro, aviso e informativas no console.
