Configuration Report Output Edit on GitHub Request doc changes
Contributors netapp-manishc
You will have an option to select fields that should be present in report output.
For System Configuration, System Risk and Storage Efficiency report, the customization is possible at field/attribute level where as for NetApp Value report, being a multi-tab report, you can select/deselect tabs you would like to view in report output.
You have option to select a customer, site, SAP group or use an already created custom group for report generation. Custom group can be created/modified by every user and can contain serial numbers spanning multiple customers or sites, if needed. Please see the see Custom Group section later in this document to see details of the process.
filter criteria for configuration output
You will be presented with the list of customer names, site names and Groups that contains the search text and will have an option to select one of them as the criteria for generating/scheduling report.
filter display for configuration output
