Contributors netapp-manishc
Create report feature allows you to create/schedule predefined reports. Currently you have an option to select one of the four reports mentioned below for report generation:
  • System Configuration
  • System Risk
  • Storage Efficiency
  • NetApp Value Report (only for internal users and partners)
Based on the report selected, you can specify the report format in which the report needs to be generated.
You will have an option to select one or more reports.
System Configuration, System Risk and Storage Efficiency Report outputs are available in Microsoft Excel and PDF formats whereas NetApp Value report is available in Microsoft Excel and PowerPoint.
You will have option to select only one report format while scheduling/generating reports.
