Get started with Health Check Assessment Dashboard
Contributors netapp-manishc netapp-reenu Download PDF of this page
This dashboard provides an at-a-glance summary of your installed base through the following widgets:
  • AutoSupport Adoption: Displays the number and percentage of systems with AutoSupport enabled. You can also view systems marked as declined, HTTPS transport, and AutoSupport on Demand. To view your health check score and information about the systems in your installed base, click the AutoSupport Adoption widget.
  • Recommended Configuration: Displays systems that are compliant and non-compliant as per the Recommended Configuration widget. It helps you take actions to ensure that your systems are well configured for HA pair and other configuration settings for remote management across your installed base. You can view the score provided on the dashboard and take actions based on the key recommendations which are provided in order of priority.
  • Recommended Software: Displays a consolidated list of all the software and firmware upgrades and currency recommendations. You can view the systems with AutoSupport enabled that should be at either the minimum or latest software or firmware versions.
  • Support & Entitlements: Displays support contracts that have expired and those that are nearing expiration within 6 to 12 months. It displays end of support platforms, disks, shelves, entitlement compliance, and pending expirations. You can view the health check score provided on the dashboard and take actions based on the key recommendations, which are provided in order of priority.
    To view detailed information about support contracts, click the Support & Entitlements widget. You can also renew your support contracts using this widget.
  • Best Practices: Displays the health check score by assessing the best practices attributes of your storage system — performance & efficiency, availability & protection, capacity, configuration, and security. NetApp best practices help sustain system health, which optimizes the performance of your installed base.
