Example 1: getAccessToken Edit on GitHub Request doc changes
Contributors netapp-manishc
The getAccessToken API is used to generate a new access token using a valid refresh token.
The following is the getAccessToken API in Java:
import io.swagger.client.*;
import io.swagger.client.auth.*;
import io.swagger.client.model.*;
import io.swagger.client.api.AccessTokenApi;
import java.io.File;
import java.util.*;
public class AccessTokenApiExample {
    public static void main(String[] args) {
        AccessTokenApi apiInstance = new AccessTokenApi();
        TokenManageraccessToken tokenManageraccessToken = ; // TokenManageraccessToken |
        try {
            tokenManagertokens result = apiInstance.getAccessToken(tokenManageraccessToken);
            System.out.println(result);
        } catch (ApiException e) {
            System.err.println("Exception when calling AccessTokenApi#getAccessToken");
            e.printStackTrace();
The following is the getAccessToken API in Android:
        try {
The following is the getAccessToken API in JavaScript:
var   ActiveIqPublicApi = require('active_iq_public_api');
var api = new ActiveIqPublicApi.AccessTokenApi()
var tokenManageraccessToken = ; // {TokenManageraccessToken}
var callback = function(error, data, response) {
  if (error) {
    console.error(error);
  } else {
    console.log('API called successfully. Returned data: ' + data);
api.getAccessToken(tokenManageraccessToken, callback);
The following is the getAccessToken API in Python:
from __future__ import print_statement
import time
import swagger_client
from swagger_client.rest import ApiException
from pprint import pprint
# create an instance of the API class
api_instance = swagger_client.AccessTokenApi()
tokenManageraccessToken =  # TokenManageraccessToken |
try:
    # Generates a new access token using a valid refresh token.
    api_response = api_instance.get_access_token(tokenManageraccessToken)
    pprint(api_response)
except ApiException as e:
    print("Exception when calling AccessTokenApi->getAccessToken: %s\n" % e)
