Example 2: getEfficiencySummaryByLevel Edit on GitHub Request doc changes
Contributors netapp-manishc
The getEfficiencySummaryByLevel API is used to provides details about the systems with maximum capacity savings for a customer, site, group, or a set of serial numbers.
The following is the getEfficiencySummaryByLevel API in Obj-C:
Configuration *apiConfig = [Configuration sharedConfig];
// Configure API key authorization: (authentication scheme: CustomAuthorizer)
[apiConfig setApiKey:@"YOUR_API_KEY" forApiKeyIdentifier:@"authorizationToken"];
// Uncomment below to setup prefix (e.g. Bearer) for API key, if needed
//[apiConfig setApiKeyPrefix:@"Bearer" forApiKeyIdentifier:@"authorizationToken"];
String *authorizationToken = authorizationToken_example; // Access token to use the 'API Services'.
String *level = level_example; // Identifies the level for which information will be provided.
Valid values are customer, site, group, and serial_numbers.
String *id = id_example; // Unique identifier for the level. Valid values are customer ID, site ID, group name, and serial numbers.
EfficiencyApi *apiInstance = [[EfficiencyApi alloc] init];
// Provides details about the systems with maximum capacity savings for a customer, site, group, or a set of serial numbers.
[apiInstance getEfficiencySummaryByLevelWith:authorizationToken
    level:level
              completionHandler: ^(storageEfficiencySummary output, NSError* error) {
                            if (output) {
                                NSLog(@"%@", output);
                            if (error) {
                                NSLog(@"Error: %@", error);
The following is the getEfficiencySummaryByLevel API in C#:
using System;
using System.Diagnostics;
using IO.Swagger.Api;
using IO.Swagger.Client;
using IO.Swagger.Model;
namespace Example
    public class getEfficiencySummaryByLevelExample
        public void main()
            // Configure API key authorization: CustomAuthorizer
            Configuration.Default.ApiKey.Add("authorizationToken", "YOUR_API_KEY");
            // Configuration.Default.ApiKeyPrefix.Add("authorizationToken", "Bearer");
            var apiInstance = new EfficiencyApi();
            var authorizationToken = authorizationToken_example;  // String | Access token to use the 'API Services'.
            var level = level_example;  // String | Identifies the level for which information will be provided.
            var id = id_example;  // String | Unique identifier for the level. Valid values are customer ID, site ID, group name, and serial numbers.
            try
                storageEfficiencySummary result = apiInstance.getEfficiencySummaryByLevel(authorizationToken, level, id);
                Debug.WriteLine(result);
            catch (Exception e)
                Debug.Print("Exception when calling EfficiencyApi.getEfficiencySummaryByLevel: " + e.Message );
The following is the getEfficiencySummaryByLevel API in PHP:
<?php
require_once(__DIR__ . '/vendor/autoload.php');
$api_instance = new Swagger\Client\Api\DefaultApi();
try {
    $api_instance->anyOptions();
} catch (Exception $e) {
    echo 'Exception when calling DefaultApi->anyOptions: ', $e->getMessage(), PHP_EOL;
The following is the getEfficiencySummaryByLevel API in Perl:
use Data::Dumper;
use WWW::SwaggerClient::Configuration;
use WWW::SwaggerClient::DefaultApi;
my $api_instance = WWW::SwaggerClient::DefaultApi->new();
eval {
if ($@) {
    warn "Exception when calling DefaultApi->anyOptions: $@\n";
