Contributors netapp-manishc
Flash Advisor recommends a list of volumes that contain workloads that will perform better if moved to AFF systems. Users can select volumes and submit a request to upgrade the system to flash.
The list of volumes is determined by looking at characteristic’s other users across the installed base have benefited from. A list of these characteristics is available from the information icon on the top right of this widget.
Criteria for determining Flash candidates
