Performance Guarantee Best Practice Gaps Edit on GitHub Request doc changes
Contributors netapp-manishc
Performance Guarantee Promotion offers Latency guarantee with select AFF A-series systems. NetApp guarantees 99% of the latency measured hourly over 100-hour period is below 1ms/500μs with select AFF A-series systems.
Performance Guarantee Best Practice Gaps widget helps to identify the systems and volumes that are not following the best practices that are defined for Performance Guarantee Promotion.
  • All volumes are managed by Adaptive QoS in the NetApp Service Level Manager with PS engagement.
  • Current ONTAP GA release.
  • Each volume size is less than 10% of the usable storage of the node.
  • No aggregate is over 80% full.
  • More than 100 average IOPS per volume per hour.
  • Random read should be greater than 30 %.
  • Average IO block size is equal to 32k or below on all volumes on a node.
  • The host application may not request more IOPS than the greater of 1k IOPs or the IOPS per gigabyte.
  • Replication or backup schedule greater than or equal to 4 hours.
  • Snapshot schedule greater than or equal to one hour.
