Storage efficiency FAQs
Download PDF of this page
How do I access Storage Efficiency in Active IQ Digital Advisor?
Open the home page of Active IQ Digital Advisor.
Search for a customer, site, group, cluster, or node from the top right search box to reach the respective dashboard.
Click Storage Efficiency from the left navigation.
| The dashboards created using a watchlist will not be displayed in the Storage Efficiency widget. |
Does Active IQ Digital Advisor display ratios for all ONTAP systems?
Active IQ displays ratios for systems running ONTAP 9.1 and later.
What is the ‘Without Snapshots’ checkbox on the efficiency dashboard?
By default, Active IQ Efficiency Dashboard calculates overall ratio at customer-level, site-level, group-level, cluster-level, and node-level. Overall ratio includes the ratio from the following storage efficiency technologies:
Deduplication
Compression
Data compaction
Clones
Snapshots
If you select the Without Snapshots checkbox, Active IQ Digital Advisor will calculate efficiency ratio (ratio from deduplication, compression, data compaction and clones storage efficiency technologies) at customer-level, site-level, group-level, cluster-level and node-level.
What is physical data used and logical data used?
Physical Blocks Consumed / Physical Data Used
The amount of space being used for data now (rather than being reserved for future use)
Includes space used by aggregate Snapshot copies
Space actually consumed/written by the client
Total Logical Data Used
Displays the logical size used in the aggregate.
This includes Volumes, Clones, and Snapshots in the aggregate.
The logical size is computed based on physical usage (real writes) and savings obtained in the aggregate.
Does not include space reserved for future use
Which AutoSupport instances are used for calculating efficiency ratios?
Calculations are performed using either the latest weekly or user-triggered AutoSupport instances which tend to contain most of the sections required for calculating the ratios.
Which volumes or aggregates are excluded from efficiency calculations?
The following objects are not considered while calculating efficiency ratios:
Root aggregates
Offline volumes
Vserver root/admin root volumes
MCC configuration volumes
How can I see the trend in efficiency ratios?
Currently, efficiency ratios are calculated based on the latest weekly or user-triggered AutoSupport instance. Efficiency trending may be considered for a future release.
How are customer-level ratios and efficiency savings calculated?
Customer-level storage efficiency dashboard provides the efficiency ratio with and without Snapshot copies for AFF and non-AFF systems and are combined across the customer installed base for systems running ONTAP 9.1 and later. The required parameters for the following calculations are taken from ONTAP AutoSupport:
Without Snapshot copies (calculated for per Aggr first):
| Operation | Formula |
Aggr Logical Used without Snapshot copies |
Logical Size Used by Volumes, Clones, Snapshot Copies in the Aggregate – Logical Size Used by Snapshot Copies |
Aggr Physical Used Without Snapshot copies |
Total Physical Used – (Physical Size Used by Snapshot copies / Aggregate Data Reduction SE Ratio) |
Customer Efficiency Ratio without Snapshot copies |
Sum [Aggr Logical Used without Snapshot copies for all aggregates and for all nodes of a customer] / Sum [Aggr Physical Used without Snapshot copies for all aggregates and for all nodes of a customer] : 1 |
With Snapshot copies:
Customer Logical Size with Snapshot copies |
Sum [Logical Size Used by Volumes, Clones, Snapshot copies for all aggregates and for all nodes of a customer] |
Customer Physical Size Used with Snapshot copies |
Sum [Total Physical Size Used for all aggregates and for all nodes of a customer] |
Customer Efficiency Ratio with Snapshot copies |
Customer Logical Size with Snapshot copies and Clones / Customer Physical Size Used with Snapshot copies and Clones : 1 |
Efficiency feature table calculations:
Customer Physical Space Used |
Sum of Physical Space Used by the Aggregate for all aggregates and of all nodes of a customer |
Customer Logical Size Used without Snapshot copies |
Sum of Logical Size Used by Volumes, Clones, Snapshot Copies - Logical Size Used by Snapshot copies for all aggregates of all nodes of a customer |
Customer Logical Size Used with Snapshot copies |
Sum of Logical Size Used by Volumes, Clones, Snapshot Copies in the Aggregate for all aggregates of all nodes of a customer |
Total Space Saved |
Total Logical Space Used – Total Physical Space Used |
Deduplication Savings |
Sum of Space Saved by Volume Deduplication + Space Saved by Inline Zero Pattern Detection of each aggregate of all nodes of a customer |
Compression Savings |
Sum of Space Saved by Volume Compression of each aggregate of all nodes of a customer |
Compaction Savings (for ONTAP 9.1) |
Sum of Space Saved by Aggregate Compaction of each aggregate of all nodes of a customer |
Compaction Savings (for ONTAP 9.2 and later) |
Sum of Space Saved by Aggregate Data Reduction of each aggregate of all nodes of a customer |
FlexClone Savings |
Sum of (Logical Size Used by FlexClone Volumes - Physical Sized Used by FlexClone Volumes) of each aggregate of all nodes of a customer |
Snapshot copies Backup Savings |
Sum of (Logical Size Used by Snapshot copies - Physical Size Used by Snapshot copies) of all aggregates of all nodes of a customer |
Why does adding all individual efficiency savings not add up to total data saved by storage efficiency?
Efficiency savings are shown in the Storage Efficiency Dashboard for volumes and local tiers (aggregates). You cannot add volume savings and aggregate savings as they both happen at different storage objects.
Why were storage efficiencies reported as higher or incorrectly before upgrading to ONTAP?
Storage efficiency is shown higher when data protection volumes are present in the node due to a bug in ONTAP. The issue was fixed in ONTAP 9.3P11. Storage Efficiency reports correct or lower values when upgraded from ONTAP versions earlier than 9.3P11 and when data protection volumes are present in the node.
How do I provide feedback or ask other questions related to Storage Efficiency?
To provide feedback or ask questions, send an email to ng-activeiq-feedback@netapp.com
Edit on GitHub
