Capacity FAQs
Download PDF of this page
How are capacities calculated in Active IQ Digital Advisor?
The capacities in Active IQ Digital Advisor are calculated for cluster and node — excluding root and including Snapshot copies
| Capacity | Calculated by adding each aggregate… |
Raw Capacity |
All Phys (MB/blks) of “SYSCONFIG -R" |
Usable Capacity |
Kbytes (Allocated) of "DF -A" |
Used Capacity (with Reserve) |
Used of “DF -A” |
Available Capacity |
Avail of “DF -A” |
Physical Capacity (Actual) |
Total Physical Used of “AGGR-EFFICIENCY.XML” |
Logical Capacity (Effective) |
Logical Size Used by Volumes, Clones, and Snapshot copies in the Aggregate of “AGGR-EFFICIENCY.XML” |
For Local tier (Aggregate with Snapshot copies)
| Capacity | Calculated by using… |
Usable Capacity |
Kbytes (allocated) of "DF -A" |
Used of “DF -A” |
Avail of “DF -A” |
For Volume (Volume with Snapshot copies)
Capacity |
Volume Capacity |
Volume Size of “VOLUME.XML” |
Used Size of "VOLUME.XML" |
Available Size of “VOLUME.XML” |
Total Physical Used of “VOL STATUS -S” |
Logical Used Size of “VOLUME.XML” |
What are Physical Capacity (Actual), Logical Capacity (Effective), and Used Capacity (with Reserve)?
Physical Blocks Consumed/Physical Capacity Used (Actual)
The amount of space being used for data now (rather than being reserved for future use)
Includes space used by aggregate Snapshot copies
Space actually consumed or written by the client
Logical Capacity (Effective) Logical Data Used
Displays the logical size used in the aggregate
The aggregate incudes Volumes, Clones, and Snapshot copies.
The logical size is computed based on physical usage (real writes) and savings obtained in the aggregate.
| It does not include space reserved for future use. |
Total Data Used/Used Capacity (with Reserve)
The sum of all space used or reserved in the aggregate by volumes, metadata, or Snapshot copies
| It includes space reserved for volumes that are of file or volume guarantee type. It includes delayed frees, aggr blog, and metadata in addition to reserves. It shows up as used space until the delayed free blocks are purged. After it is purged, the used space decreases. |
Why does added Used Capacity of each volume not match the aggregated Used Capacity at the node level?
Used Capacity at the node level includes space reserved by volumes, metadata, and Snapshot copies. It also includes space reserved for volumes—file or volume guarantee type. Hence, both might not match.
Are Capacities shown in Active IQ Digital Advisor Base 2 or Base 10?
All capacities displayed in Active IQ are Base 2 (divide by 1024) and represent capacities in GiB/TiB. ONTAP storage and other NetApp products also display capacity usage in Base 2.
For StorageGRID, capacities are displayed in Base 10 and the unit of capacity is expressed in TB.
Edit on GitHub
