View cluster and node configuration
Download PDF of this page
The ClusterViewer enables you to view detailed physical and logical configuration information. The details are presented in several easy-to-view tables across multiple tabs that include a summary of the cluster and node configuration, the local tier and volume information, the network interface and port information, a stack diagram detailing information about the disks and shelves, and a few cable visualizations. You can also download the cable visualization graphics in the SVG format.
At the cluster level, click View Details next to the Cluster Configuration widget.
Click the Visualization tab to view a graphical representation of the cluster.
