Digital Advisor
View risks for actions in Digital Advisor and mitigate using Unified Manager or Ansible Playbook
Contributors manishc netapp-barbe FarheenViquas
You can analyze your storage system by viewing the actions and risks, and mitigate them using Active IQ Unified Manager or Ansible Playbook.
Steps
  1. Select View All Actions on the dashboard.
  2. Select Actions to view the risks associated with the actions, select Risks to view all the risks, or select Affected Systems to view the systems that require attention.
    If the risk can be mitigated using Active IQ Unified Manager, the Spanner icon is highlighted and if the risk can be mitigated using Ansible Playbook, the Update Ansible icon is highlighted.
To mitigate the risk using Unified Manager To mitigate the risk using Ansible Playbook
  1. Select the Spanner icon.
  2. Select Fix It to launch Active IQ Unified Manager.
  3. Select Install to install Active IQ Unified Manager 9.7 or later to use the Fix It option.
  4. Select Upgrade to upgrade to Active IQ Unified Manager 9.7 or later to use the Fix It option.
  1. Select the Update Ansible icon.
  2. Select Download to download the AFF and FAS firmware Ansible Automation package.
Note A SupportEdge Advisor or SupportEdge Expert contract is required to use the Fix It option and the Ansible Playbook features.
