Digital Advisor
View firmware update recommendations in Digital Advisor
Contributors netapp-barbe netapp-manishc
Customers can now save time and effort by allowing Control Tower to automatically update their systems with the latest firmware versions, eliminating the need for manual intervention or scheduling. This update reduces the risk of encountering issues due to outdated or incompatible firmware versions, ensuring optimal system performance, stability, and security.
Customers will receive timely notifications and alerts about the status of the firmware updates, with options to enable AutoSupport and auto-update settings.
Steps
  1. On the dashboard page, select Other recommendations in the Upgrade Advisor widget.
  2. Select View recommendations to view the list of recommendations.
  3. In the Update Status column, select See progress to view the clusters that are eligible for an update.
  4. In case of any issues, select the respective links to view the steps to mitigate the issues.
