Replace a node in your AI Data Engine cluster
You need to replace a data compute node in your AI Data Engine (AIDE) cluster if it stops functioning or needs to be swapped due to hardware failure, upgrade, or maintenance. This ensures the AIDE cluster remains healthy and operational. The procedure can be performed without disrupting ongoing services.
Prepare to replace a node
There are several things to consider before replacing a node in your AIDE cluster.
Requirements
You'll need the following:
User credentials with storage administrator privileges
Serial number for the new replacement node
Restrictions
You should be aware of the following restrictions when replacing a node in your AIDE cluster:
Node replacement is only supported using the CLI and optionally the REST API.
You cannot perform node replacement using System Manager.
The new node should match the cluster's software version; ONTAP will update it if needed.
The failed node must not be powered on while connected to the cluster network to avoid IP address conflicts.
Replace a data compute node in your AIDE cluster
You can replace a data compute node in your AIDE cluster using the following procedure.
Physically remove the failed node
Power off and disconnect the node from the cluster network. Make sure the node is not booted up on the network during the replacement process.
Delete the failed node from the cluster using the following command:
dcn cluster node delete -name <node_name> -force trueProvide the actual name for the <node_name> value.
Physically attach the new node to the cluster
Make sure the node is cabled in, powered on, and discoverable.
View the discoverable and unconfigured nodes to verify the new node is online:
dcn cluster node show -membership available -
Add the node to the cluster using the following command:
dcn cluster node create -serial-number <new_node_serial>ONTAP will allocate an IP address for the new node. If the node's software version does not match the cluster, ONTAP will automatically update the node.
Verify cluster health and node integration with either of the following commands:
dcn cluster node showdcn cluster node show -instance
