AI Data Engine
Kerberos authentication for SMB/CIFS shares in AI Data Engine
Contributors netapp-dbagwell
Scan SMB/CIFS shares by using Kerberos authentication, so that no password is stored in the data source. AI Data Engine (AIDE) acts as a Kerberos client. It uses a keytab for a scan service account to get Kerberos tickets from your existing Active Directory domain controller.
Kerberos authentication applies to SMB/CIFS data sources. To map NFS user and group IDs to Active Directory names, refer to Configure Active Directory identity mapping for NFS.
How Kerberos scanning works
After setup, AI Data Engine gets and refreshes Kerberos tickets automatically, so you don't manage credentials for each scan.
  1. You create three files: a Kerberos configuration file, a keytab for the scan service account, and a principal file that names the account.
  2. AI Data Engine uses the keytab to get a Kerberos ticket from your Active Directory domain controller, which acts as the Kerberos key distribution center (KDC). AI Data Engine refreshes the ticket every three hours.
  3. When you add an SMB/CIFS share and select Kerberos as the authentication method, AI Data Engine scans the share by using the ticket.
AI Data Engine finds your domain controller and your file server by name. The host or nodes must resolve both names by using a DNS server that can resolve your Active Directory names. If you point the host or nodes to your Active Directory DNS server, that server must also resolve external names. On a multi-node deployment, it must be the only name server on every node.
If you replace the Kerberos configuration file after setup, AI Data Engine continues to use the previous file until you restart the affected services. For the steps, refer to Update the Kerberos configuration file for a single-node deployment or Update the Kerberos configuration file for a multi-node deployment.
Choose a procedure
The Kerberos files, the host packages, and the verification steps depend on your deployment type.
Deployment Where the Kerberos files live Packages Procedure
Single-node
On the AI Data Engine host. The Kerberos configuration file is /etc/krb5.conf.
Install the Kerberos client tools on the host. The installer installs cifs-utils.
Configure Kerberos for SMB/CIFS shares on a single-node AI Data Engine deployment
Multi-node
On the shared NFS export that holds the AI Data Engine configuration. The nodes don't use /etc/krb5.conf.
Install the Kerberos client tools on one admin host. Install cifs-utils on every node.
Configure Kerberos for SMB/CIFS shares on a multi-node AI Data Engine deployment
What you need
Gather these details so you can configure Kerberos access to the SMB/CIFS shares you want to scan.
  • A scan service account in Active Directory with read access to the SMB/CIFS shares that you want to scan. The account must support AES256 encryption.
  • The IP address and the FQDN of a domain controller that acts as the KDC.
  • Your Active Directory domain and Kerberos realm. The realm is the domain in uppercase.
  • The FQDN and the share name of each file server that you want to scan. Kerberos authentication doesn't accept an IP address for the file server.
  • Root access to the AI Data Engine host for a single-node deployment. For a multi-node deployment, root access to every node and to the admin host, and kubectl access with cluster-admin privileges from the admin host.
  • For a multi-node deployment, access from every node to the NFS server on TCP port 2049.
Also verify that your environment meets the networking requirements and the Kerberos and Active Directory requirements, including time synchronization, DNS, and host packages.
