AI Data Engine
Manage users and roles in AI Data Engine
Contributors netapp-dbagwell
Control what each user can view and do in AI Data Engine (AIDE) by assigning them an administrator or viewer role. Before your team starts using AI Data Engine, assign each user the role that matches their required level of access.
You assign roles through NetApp Console organization settings. AI Data Engine supports two roles.
Available roles
AI Data Engine administrator
The AI Data Engine administrator role provides full access to all AI Data Engine capabilities. NetApp recommends assigning this role to no more than two or three users per deployment.
AI Data Engine viewer
The AI Data Engine viewer role provides limited access to AI Data Engine. Viewers can view information, export reports, tag files, and create monitor-only policies, but can't modify settings or perform file actions such as archive, copy, or delete.
Permissions by role
Capability AI Data Engine administrator AI Data Engine viewer
Yes
Manage data resources
Yes
System configuration
Yes
View dashboards
Yes
Yes
Search metadata (Investigation)
Yes
Yes
Export reports
Yes
Yes
Create monitor-only policies
Yes
Yes
Create policies with actions
Yes
Actions: Tag
Yes
Yes
Actions: Archive, Copy, Delete
Yes
Actions: Clean up duplicates
Yes
Manage business tags
Yes
Yes
Roles and governed AI access
NetApp Console roles control who can configure governed AI access in AI Data Engine. They don't control which collections an AI client user can search. Microsoft Entra ID scopes that you grant to each collection control that access. For details, refer to Configure Microsoft Entra ID for governed AI access.
Assign a role to a user
You assign roles in NetApp Console, not within AI Data Engine itself.
Steps
  1. From NetApp Console, select Administration > Identity and access.
  2. Go to Members.
  3. Do one of the following:
    • To add a new user, select Add user and enter the user's email address.
    • To update an existing user, select the user from the list.
  4. Select the organization, folder, or project, and then choose the Data Service category.
  5. Assign the AI data engine administrator or AI data engine viewer role.
  6. Add the new role.
The user receives an email invitation and can access AI Data Engine after accepting it.
