Update AI Data Engine software
As a storage administrator, you can update AI Data Engine (AIDE) software, NetApp DCN firmware, and other system files on your AIDE system using ONTAP System Manager.
AIDE does not support ONTAP automatic software updates functionality. You can sign up to receive notifications from NetApp Support Site downloads, but all updates of AIDE software are performed manually by the admin.
The combined AIDE software package is significantly larger than a typical ONTAP update package (AIDE package is approximately 40GB). Plan for longer upload and installation times when updating AIDE software.
You need storage administrator privileges to update NetApp DCN firmware and AIDE software.
You need your NetApp Support Site credentials for your active account.
Ensure compatibility between ONTAP, NetApp DCN firmware, and AIDE software when planning updates.
Revert functionality is not supported for NetApp DCN firmware or AIDE software updates. After an update is installed, you cannot revert to a previous version. |
Download the combined NetApp DCN firmware and AIDE software update file to a local client.
In System Manager, select Cluster > Settings > Software updates.
Next to Software updates, select
Under AI Data Engine updates, select Add AI Data Engine software files and select the update package.
After package upload is complete, select Update to begin installing updates on the NetApp DCNs.
AIDE Console is not available or accessible when the NetApp DCN update is in progress.
NetApp DCNs are updated with AIDE software and the updated version is displayed for each node.
