AI Data Engine
View Insights to optimize your AI Data Engine system
Contributors netapp-dbagwell
As a storage administrator, you can use the Insights feature of ONTAP System Manager to display suggested configuration updates that align with NetApp best practices. These changes can optimize the security and performance of your AI Data Engine (AIDE) cluster.
About this task
Each of the insights is presented as a separate tile or card on the page that you can choose to implement or dismiss. You can also select the associated documentation link to learn more about a specific technology.
Steps
  1. In System Manager, select Analysis and then Insights.
  2. Review the available recommendations.
What's next
Perform any of the recommended actions to implement configuration best practices.
