AI Data Engine
Learn how AI Data Engine storage administrators work with AIDE components
Contributors netapp-dbagwell
As a storage administrator, you manage the AIDE infrastructure through ONTAP and AI Data Engine (AIDE) Console, provisioning workspaces, attaching guardrail policies, and monitoring system health. Your role focuses on ensuring reliable, secure, and compliant data storage for AI workloads.
Storage administrator component access
Component Access level Storage administrator workflow
ONTAP System Manager
Manage (create, edit, delete)
You use ONTAP System Manager as your primary interface for cluster administration, workspace provisioning, guardrail policy management, and monitoring system health.
AIDE Console
You use AIDE Console to monitor workspaces, view collection status, and oversee system activity across the AIDE environment.
ONTAP REST API
You use the REST API to automate infrastructure tasks, manage workspaces and guardrail policies programmatically, and integrate AIDE administration with external tools and workflows.
Workspaces
You create and manage workspaces using ONTAP System Manager. You select which data sources are included, assign permissions to data engineers and data scientists, and attach guardrail policies to enforce governance and compliance. You also monitor workspace health and access.
Data collections
View (read-only)
You view the status and health of data collections within each workspace using System Manager. You ensure underlying data sources are available and protected, but you do not create or modify collections.
Guardrails
You define and attach guardrail policies to workspaces using System Manager. You monitor guardrail status and compliance reports. You ensure policies are enforced and updated as needed.
Metadata catalog
Monitor (view health, status, activity)
You ensure the metadata catalog is populated and up to date. You monitor catalog health and support access control.
Vector database
Provision/Monitor (deploy, configure, view status)
You provision and monitor the vector database infrastructure, ensuring data compute nodes with GPU resources and proper licensing are in place. You support the environment but do not manage embeddings or queries directly.
Classifiers
You create, configure, and manage classifiers and their categories. You apply classifiers to workspaces and monitor their effectiveness.
