Revert ONTAP on ASA r2 storage systems
ONTAP software reverts for ASA r2 systems follow the same process as reverts for other ONTAP systems.
Reverting an ONTAP cluster is disruptive. You must take the cluster offline for the duration of the reversion. You should not revert a production cluster without assistance from technical support. You can revert a new or test cluster without assistance. If the revert of a new or test system fails, or if it finishes successfully but you are not satisfied with the cluster performance in your production environment, contact technical support for assistance.
See Revert an ONTAP cluster for the full revert procedure.
Revert requirements for ASA r2 systems
Certain ASA r2 cluster configurations require you to take specific actions before you begin an ONTAP software revert.
Reverting from ONTAP 9.17.1
If you are reverting from ONTAP 9.17.1 on an ASA r2 system, you should perform the following actions before you begin the revert:
Dynamic space balancing is enabled by default 14 days after either upgrading to ONTAP 9.17.1 or initializing a new ONTAP 9.17.1 ASA r2 cluster. You cannot revert from ONTAP 9.17.1 on your ASA r2 system after dynamic space balancing is enabled. |
| If you have… | Before you revert you should… |
Hierarchical consistency groups in a SnapMirror active sync relationship |
Active import relationships |
Delete the active import relationships. |
Anti-ransomware protection enabled |
