Move storage units on ASA r2 storage systems
If a storage availability zone is running low on space, you can move storage units to another storage availability zone to balance the storage utilization across the cluster.
You can move a storage unit while it is online and serving data. The move operation is non-disruptive.
Before you begin
You must be running ONTAP 9.16.1 or later.
Your cluster must consist of four or more nodes.
Steps
In System Manager, select Storage; then select the storage unit you want to move.
Select
; then select Move. -
Select the storage availability zone you want to move the storage unit to; then select Move.
