Manage the cluster
Contributors amgrissino netapp-mwallis
You can manage the cluster by using kubectl commands with Astra Data Store preview.
What you’ll need
Place a node in maintenance mode
When you need to perform host maintenance or package upgrades, you should place the node in maintenance mode.
Note The node must already be part of the Astra Data Store preview cluster.
When a node is in maintenance mode, you cannot add a node to the cluster. In this example, we will place nhcitjj1525 into mainteance mode.
Steps
  1. Display the node details:
    ~% kubectl get nodes
    >> Show the output of 'kubectl get nodes'.
     [root@scs000039783-1 ~]# kubectl get nodes
     NAME             STATUS   ROLES                  AGE     VERSION
     nhcitjj1525      Ready    <none>                 3d18h   v1.20.0
     nhcitjj1526      Ready    <none>                 3d18h   v1.20.0
     nhcitjj1527      Ready    <none>                 3d18h   v1.20.0
     nhcitjj1528      Ready    <none>                 3d18h   v1.20.0
     scs000039783-1   Ready    control-plane,master   3d18h   v1.20.0
  2. Ensure that the node is not already in maintenance mode:
    ~% kubectl astrads maintenance list
    NAME    NODE NAME  IN MAINTENANCE  MAINTENANCE STATE       MAINTENANCE VARIANT
    kubectl astrads    maintenance     create node4 --node-name="nhcitjj1525" --variant=Node
    Maintenance mode astrads-system/node4 created
  3. Enable maintenance mode.
    ~% kubectl astrads maintenance create <cr-name> --node-name=<<node-name>> --variant=Node
    ~% kubectl astrads maintenance create maint1 --node-name="nhcitjj1525" --variant=Node
    Maintenance mode astrads-system/maint1 created
  4. List the nodes.
    ~% kubectl astrads nodes list
    NODE NAME       NODE STATUS     CLUSTER NAME
    nhcitjj1525     Added           ftap-astra-012
    nhcitjj1527     Added           ftap-astra-012
    nhcitjj1526     Added           ftap-astra-012
    nhcitjj1528     Added           ftap-astra-012
  5. Check the status of the maintenance mode:
    node4   nhcitjj1525     true            ReadyForMaintenance     Node
    The In Maintenance mode starts as "False" and changes to "True."
    The Maintenance state changes from "Preparing for Maintenance" to "Ready for Maintenance."
  6. After the node maintenance is complete, disable maintenance mode:
    ~% kubectl astrads maintenance update maint1 --node-name="nhcitjj1525" --variant=None
  7. Ensure that the node is no longer in maintenance mode:
Add a node
The node that you are adding should be part of the Kubernetes cluster and should have a configuration that is similar to the other nodes in the cluster.
Steps
  1. If the new node’s dataIP is not already part of the ADSCluster CR, do the following:
    1. Edit the astradscluster CR and add the additional dataIP in the ADS Data Networks Addresses field:
      ~% kubectl edit astradscluster <cluster-name> -n astrads-system
      ADS Data Networks:
          Addresses:  dataIP1, dataIP2, dataIP3, dataIP4, *newdataIP*
    2. Save the CR file.
    3. Add the node to the Astra Data Store preview cluster:
      ~% kubectl astrads nodes add –cluster <cluster-name>
  2. Otherwise, just add the nodes:
  3. Verify that the node has been added:
Replace a node
Use kubectl commands with Astra Data Store preview to replace a failed node in a cluster.
Steps
  1. List all the nodes:
    sti-rx2540-534d..   Added       cluster-multinodes-21209
    sti-rx2540-535d...  Added       cluster-multinodes-21209
  2. Describe the cluster:
    ~% kubectl astrads clusters list
    CLUSTER NAME               CLUSTER STATUS  NODE COUNT
    cluster-multinodes-21209   created         4
  3. Verify that the Node HA is marked as "False" on the failed node:
    ~% kubectl describe astradscluster -n astrads-system
    Namespace:    astrads-system
    Labels:       <none>
    Annotations:  kubectl.kubernetes.io/last-applied-configuration:
                    {"apiVersion":"astrads.netapp.io/v1alpha1","kind":"AstraDSCluster","metadata":{"annotations":{},"name":"cluster-multinodes-21209","namespa...
    API Version:  astrads.netapp.io/v1alpha1
    Kind:         AstraDSCluster
    State:               Disabled
    Variant:             None
    Node HA:             false
    Node ID:             4
    Node Is Reachable:   false
    Node Management IP:  172.21.192.192
    Node Name:           sti-rx2540-532d.ctl.gdl.englab.netapp.com
    Node Role:           Storage
    Node UUID:           6f6b88f3-8411-56e5-b1f0-a8e8d0c946db
    Node Version:        12.75.0.6167444
    Status:              Added
  4. Modify the Cluster CR to remove the failed node. The node count decrements to 3:
     # cat manifests/astradscluster.yaml
    apiVersion: astrads.netapp.io/v1alpha1
    kind: AstraDSCluster
    metadata:
      namespace: astrads-system
    spec:
      # ADS Node Configuration per node settings
      adsNodeConfig:
        # Specify CPU limit for ADS components
        # Supported value: 9
        cpu: 9
        # Specify Memory Limit in GiB for ADS Components.
        # Your kubernetes worker nodes need to have at least this much RAM free
        # for ADS to function correctly
        # Supported value: 34
        memory: 34
        # [Optional] Specify raw storage consumption limit. The operator will only select drives for a node up to this limit
        capacity: 600
        # [Optional] Set a cache device if you do not want auto detection e.g. /dev/sdb
        # cacheDevice: ""
        # Set this regex filter to select drives for ADS cluster
        # drivesFilter: ".*"
      # [Optional] Specify node selector labels to select the nodes for creating ADS cluster
      # adsNodeSelector:
      #   matchLabels:
      #     customLabelKey: customLabelValue
      # Specify the number of nodes that should be used for creating ADS cluster
      adsNodeCount: 3
      # Specify the IP address of a floating management IP routable from any worker node in the cluster
      mvip: "172..."
      # Comma separated list of floating IP addresses routable from any host where you intend to mount a NetApp Volume
      # at least one per node must be specified
      # addresses: 10.0.0.1,10.0.0.2,10.0.0.3,10.0.0.4,10.0.0.5
      # netmask: 255.255.255.0
      adsDataNetworks:
        - addresses: "172..."
          netmask: 255.255.252.0
      # [Optional] Provide a k8s label key that defines which protection domain a node belongs to
      # adsProtectionDomainKey: ""
      # [Optional] Provide a monitoring config to be used to setup/configure a monitoring agent.
      monitoringConfig:
       namespace: "netapp-monitoring"
       repo: "docker.repo.eng.netapp.com/global/astra"
      autoSupportConfig:
        # AutoUpload defines the flag to enable or disable AutoSupport upload in the cluster (true/false)
        autoUpload: true
        # Enabled defines the flag to enable or disable automatic AutoSupport collection.
        # When set to false, periodic and event driven AutoSupport collection would be disabled.
        # It is still possible to trigger an AutoSupport manually while AutoSupport is disabled
        # enabled: true
        # CoredumpUpload defines the flag to enable or disable the upload of coredumps for this ADS Cluster
        # coredumpUpload: false
        # HistoryRetentionCount defines the number of local (not uploaded) AutoSupport Custom Resources to retain in the cluster before deletion
        historyRetentionCount: 25
        # DestinationURL defines the endpoint to transfer the AutoSupport bundle collection
        destinationURL: "https://testbed.netapp.com/put/AsupPut"
        # ProxyURL defines the URL of the proxy with port to be used for AutoSupport bundle transfer
        # proxyURL:
        # Periodic defines the config for periodic/scheduled AutoSupport objects
        periodic:
          # Schedule defines the Kubernetes Cronjob schedule
          - schedule: "0 0 * * *"
            # PeriodicConfig defines the fields needed to create the Periodic AutoSupports
            periodicconfig:
            - component:
                event: dailyMonitoring
              userMessage: Daily Monitoring Storage AutoSupport bundle
              nodes: all
            - component:
                event: daily
              userMessage: Daily Control Plane AutoSupport bundle
    [root@scspr2409016001 42733317_42952507_1x5Node_Astra_DAS-002]# cat manifests/astradscluster.yaml
    metadata:
    spec:
      adsNodeConfig:
        cpu: 9
        memory: 34
        capacity: 600
        # cacheDevice: ""
      # adsNodeSelector:
      #   matchLabels:
      adsNodeCount: 3
      mvip: "172..."
      adsDataNetworks:
      # [Optional] Specify the network interface names for either all or none
      adsNetworkInterfaces:
        managementInterface: "mgmt"
        clusterInterface: "data"
        storageInterface: "data"
      monitoringConfig:
      autoSupportConfig:
        autoUpload: true
        # enabled: true
        # proxyURL:
        periodic:
            periodicconfig:
            - component:
              nodes: all
            - component:
                event: daily
     kubectl apply -f manifests/astradscluster.yaml
    astradscluster.astrads.netapp.io/cluster-multinodes-21209 configured
  5. Verify the node is removed from the cluster:
    ~% kubectl get nodes --show-labels
    NAME                                            STATUS   ROLES                 AGE   VERSION   LABELS
    sti-astramaster-237   Ready control-plane,master   24h   v1.20.0
    sti-rx2540-532d       Ready  <none>                24h   v1.20.0
    sti-rx2540-533d       Ready  <none>                24h
    sti-rx2540-534d   Added           cluster-multinodes-21209
    sti-rx2540-535d   Added           cluster-multinodes-21209
    sti-rx2540-536d   Added           cluster-multinodes-21209
    Labels:       <none>
    Metadata:
  6. Add a node to the cluster for replacement by modifying the cluster CR. The node count increments to 4. Verify that new node is picked up for addition.
    rvi manifests/astradscluster.yaml
    metadata:
    ~% kubectl apply -f manifests/astradscluster.yaml
    ~% kubectl get pods -n astrads-system
    NAME                                READY   STATUS    RESTARTS   AGE
    astrads-cluster-controller...       1/1     Running   1          24h
    astrads-deployment-support...       3/3     Running   0          24h
    astrads-ds-cluster-multinodes-21209 1/1     Running
    sti-rx2540-534d...       Added           cluster-multinodes-21209
    ~% kubectl astrads drives list
    DRIVE NAME    DRIVE ID    DRIVE STATUS   NODE NAME     CLUSTER NAME
    scsi-36000..  c3e197f2... Active         sti-rx2540... cluster-multinodes-21209
Replace a drive
When a drive fails in a cluster, the drive must be replaced as soon as possible to ensure data integrity.
When a drive fails, you will see failed drive information in cluster CR node status, cluster health condition information, and the metrics endpoint.
Example of cluster showing failed drive in nodeStatuses.driveStatuses
$ kubectl get adscl -A -o yaml
nodeStatuses:
  - driveStatuses:
    - driveID: 31205e51-f592-59e3-b6ec-185fd25888fa
      driveName: scsi-36000c290ace209465271ed6b8589b494
      drivesStatus: Failed
    - driveID: 3b515b09-3e95-5d25-a583-bee531ff3f31
      driveName: scsi-36000c290ef2632627cb167a03b431a5f
      drivesStatus: Active
    - driveID: 0807fa06-35ce-5a46-9c25-f1669def8c8e
      driveName: scsi-36000c292c8fc037c9f7e97a49e3e2708
Example of new AstraDSFailedDrive CR
The failed drive CR is created automtically in the cluster with a name corresponding to the UUID of the failed drive.
$ kubectl get adsfd -A -o yaml
kind: AstraDSFailedDrive
metadata:
spec:
  executeReplace: false
  replaceWith: ""
 status:
   cluster: arda-6e4b4af
   failedDriveInfo:
     failureReason: AdminFailed
     inUse: false
     path: /dev/disk/by-id/scsi-36000c290ace209465271ed6b8589b494
     present: true
     serial: 6000c290ace209465271ed6b8589b494
     node: sti-rx2540-300b.ctl.gdl.englab.netapp.com
   state: ReadyToReplace
Steps
  1. List possible replacement drives with the kubectl astrads show-replacements command, which filters drives that fit replacement restrictions (unused in cluster, not mounted, no partitions, and equal or larger than failed drive).
    To list all drives without filtering possible replacement drives, add --all to show-replacements command.
    ~% kubectl astrads faileddrive list --cluster arda-6e4b4af
    NAME       NODE                             CLUSTER        STATE                AGE
    6000c290   sti-rx2540-300b.lab.netapp.com   ard-6e4b4af    ReadyToReplace       13m
    ~%  kubectl astrads faileddrive show-replacements --cluster ard-6e4b4af --name 6000c290
    NAME  IDPATH             SERIAL  PARTITIONCOUNT   MOUNTED   SIZE
    sdh   /scsi-36000c29417  45000c  0                false     100GB
  2. Use the replace command to replace the drive with the passed serial number. The command completes the replacement or fails if `--wait time elapses.
    ~% kubectl astrads faileddrive replace --cluster arda-6e4b4af --name 6000c290 --replaceWith 45000c --wait
    Drive replacement completed successfully
  3. If kubectl astrads faileddrive replace is executed using an inappropriate --replaceWith serial number, an error appears similar to this:
    ~% kubectl astrads replacedrive replace --cluster astrads-cluster-f51b10a --name 6000c2927 --replaceWith BAD_SERIAL_NUMBER
    Drive 6000c2927 replacement started
    Failed drive 6000c2927 has been set to use BAD_SERIAL_NUMBER as a replacement
    Drive replacement didn't complete within 25 seconds
    Current status: {FailedDriveInfo:{InUse:false Present:true Name:scsi-36000c2 FiretapUUID:444a5468 Serial:6000c Path:/scsi-36000c FailureReason:AdminFailed Node:sti-b200-0214a.lab.netapp.com} Cluster:astrads-cluster-f51b10a State:ReadyToReplace Conditions:[{Message: "Replacement drive serial specified doesn't exist", Reason: "DriveSelectionFailed", Status: False, Type:' Done"]}
  4. To re-run drive replacement use `--force with the previous command:
    ~%  kubectl astrads replacedrive replace --cluster astrads-cluster-f51b10a --name 6000c2927 --replaceWith VALID_SERIAL_NUMBER --force
