BeeGFS on NetApp with E-Series Storage
High capacity building block
Contributors mcwhiteside Noah-Hardy codyharryman
The standard BeeGFS solution design is built with high performance workloads in mind. Customers looking for a high capacity use cases should observe the variations in design and performance characteristics outlined here.
Hardware and software configuration
Hardware and software configuration for the high capacity building block is standard except that the EF600 controllers should be replaced with a EF300 controllers with an option to attach between 1 and 7 IOM expansion trays with 60 drives each for each storage array, totaling 2 to 14 expansions trays per building block.
Customers deploying a high capacity building block design are likely to use only the base building block style configuration consisting of BeeGFS management, metadata, and storage services for each node. For cost efficiency, high capacity storage nodes should provision metadata volumes on the NVMe drives in the EF300 controller enclosure and should provision storage volumes to the NL-SAS drives in the expansion trays.
A diagram that shows a BeeGFS high-capacity rack with EF300 NVMe and NL-SAS IOM expansion trays
Sizing guidelines
These sizing guidelines assume high capacity building blocks are configured with one 2+2 NVMe SSD volume group for metadata in the base EF300 enclosure and 6x 8+2 NL-SAS volume groups per IOM expansion tray for storage.
Drive size (capacity HDDs) Capacity per BB (1 Tray) Capacity per BB (2 Trays) Capacity per BB (3 Trays) Capacity per BB (4 Trays)
4TB
439TB
878 TB
1317 TB
1756 TB
8 TB
878 TB
1756 TB
2634 TB
3512 TB
10 TB
1097 TB
2195 TB
3292 TB
4390 TB
12 TB
1317 TB
2634 TB
3951 TB
5268 TB
16 TB
1756 TB
3512 TB
5268 TB
7024 TB
18 TB
1975 TB
3951 TB
5927 TB
7902 TB
