BlueXP backup and recovery
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Supported Google archive storage tiers with BlueXP backup and recovery
Contributors amgrissino
BlueXP backup and recovery supports one Google archival storage class and most regions.
NOTE To switch to and from BlueXP backup and recovery UI versions, refer to Switch to the previous BlueXP backup and recovery UI.
Supported Google archival storage classes for BlueXP backup and recovery
When backup files are initially created they're stored in Standard storage. This tier is optimized for storing data that's infrequently accessed; but that also allows you to access it immediately.
If your on-prem cluster is using ONTAP 9.12.1 or greater, you can choose to tier older backups to Archive storage in the BlueXP backup and recovery UI after a certain number of days (typically more than 30 days) for further cost optimization. Data in this tier will require a higher retrieval cost, so you need to consider how often you may need to restore data from these archived backup files. See the section on this page about restoring data from archival storage.
Note that when you configure BlueXP backup and recovery with this type of lifecycle rule, you must not configure any lifecycle rules when setting up the bucket in your Google account.
Restore data from archival storage
While storing older backup files in Archive storage is much less expensive than Standard storage, accessing data from a backup file in Archive storage for restore operations will take a slightly longer amount of time and will cost more money.
How much does it cost to restore data from Google Archive?
For detailed Google Cloud Storage pricing by region, visit the Google Cloud Storage pricing page.
How long will it take to restore my objects archived in Google Archive?
There are 2 parts that make up the total restore time:
  • Retrieval time: The time to retrieve the backup file from Archive and place it in Standard storage. This is sometimes called the "rehydration" time. Unlike the "coldest" storage solutions provided by other cloud providers, your data is accessible within milliseconds.
  • Restore time: The time to restore the data from the backup file in Standard storage. This time is no different than the typical restore operation directly from Standard storage - when not using an archival tier.
