Manage the Cloud Volumes ONTAP aggregate capacity on a Connector
Each Connector has settings that determines how it manages aggregate capacity for Cloud Volumes ONTAP.
These settings affect all Cloud Volumes ONTAP systems managed by a Connector. If you have another Connector, it can be configured differently.
BlueXP Organization or Account admin privileges are required to modify Cloud Volumes ONTAP Settings.
In the upper right of the BlueXP console, click the Settings icon, and select Cloud Volumes ONTAP Settings.
Under Capacity, modify any of the following settings:
- Capacity Management Mode
Choose whether BlueXP notifies you of storage capacity decisions or whether BlueXP automatically manages capacity requirements for you.
- Aggregate Capacity Threshold - Free Space Ratio
This ratio is a key parameter in capacity management decisions, and understanding its impact is essential regardless of whether you are in an automatic or manual mode of capacity management. It is recommended to set this threshold with consideration of your specific storage needs and anticipated growth to maintain a balance between resource utilization and cost.
In the manual mode, if the free space ratio on an aggregate drops below the specified threshold, it triggers a notification, alerting you that you should take actions to address the low free space ratio. It is important to monitor these notifications and manually manage the aggregate capacity to avoid service disruption and ensure optimal performance.
The free space ratio is calculated as follows:
(aggregate capacity - total used capacity on the aggregate) / aggregate capacityRefer to Automatic capacity management to learn now capacity is automatically managed in Cloud Volumes ONTAP.
- Aggregate Capacity Thresholds - Free Space Ratio for Data Tiering
Defines how much free space is required on the performance tier (disks) when tiering data to a capacity tier (object storage).
The ratio is important for disaster recovery scenarios. As data is read from the capacity tier, Cloud Volumes ONTAP moves data to the performance tier to provide better performance. If there isn't sufficient space, then Cloud Volumes ONTAP can't move the data.
Click Save.
