Cloud Volumes ONTAP
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
License management for node-based BYOL
Contributors netapp-manini
Each Cloud Volumes ONTAP system that has a node-based bring your own license (BYOL) must have a system license installed with an active subscription. The NetApp Console simplifies the process by managing licenses for you and by displaying a warning before they expire.
Note A node-based license is the previous generation license for Cloud Volumes ONTAP. A node-based license could be procured from NetApp (BYOL) and is available for license renewals, only in specific cases.
BYOL system licenses
Node-based licenses could be procured from NetApp. The number of licenses that you can purchase for a single-node system or HA pair is unlimited.
Note NetApp has restricted the purchase, extension, and renewal of BYOL licensing. For more information, refer to Restricted availability of BYOL licensing for Cloud Volumes ONTAPP.
A node-based license provides up to 368 TiB of capacity for a single node or HA pair. You might have purchased multiple licenses for a Cloud Volumes ONTAP BYOL system to allocate more than 368 TiB of capacity. For example, you might have two licenses to allocate up to 736 TiB of capacity to Cloud Volumes ONTAP. Or you could have four licenses to get up to 1.4 PiB.
Be aware that disk limits can prevent you from reaching the capacity limit by using disks alone. You can go beyond the disk limit by tiering inactive data to object storage. For information about disk limits, refer to storage limits in the Cloud Volumes ONTAP Release Notes.
License management for a new system
When you create a node-based BYOL system, the Console prompts you for the serial number of your license and your NetApp Support Site account. The Console uses the account to download the license file from NetApp and to install it on the Cloud Volumes ONTAP system.
If the Console can't access the license file over the secure internet connection, you can obtain the file yourself and then manually upload the file to the Console.
License expiration
The Console displays a warning 30 days before a node-based license is due to expire and again when the license expires. The following image shows a 30-day expiration warning that appears in the user interface:
Screen shot: Shows a Cloud Volumes ONTAP system that includes a warning icon. The icon indicates that an action is required.
You can select the system to review the message.
The Console includes a license expiration warning in the Cloud Volumes ONTAP report that's emailed to you, if you are an organization or account admin and you enabled the option. The emailed report includes the license expiration warning every 2 weeks.
If you don't renew the license in time, the Cloud Volumes ONTAP system shuts itself down. If you restart it, it shuts itself down again.
License renewal
If you renew a node-based BYOL subscription by contacting a NetApp representative, the Console automatically obtains the new license from NetApp and installs it on the Cloud Volumes ONTAP system.
License transfer to a new system
A node-based BYOL license is transferable between Cloud Volumes ONTAP systems when you delete an existing system and then create a new one using the same license.
For example, you might want to delete an existing licensed system and then use the license with a new BYOL system in a different VPC/VNet or cloud provider. Note that only cloud-agnostic serial numbers work in any cloud provider. Cloud-agnostic serial numbers start with the 908xxxx prefix.
It's important to note that your BYOL license is tied to your company and a specific set of NetApp Support Site credentials.
