Add an existing Cloud Volumes ONTAP system to NetApp Console
You can discover and add existing Cloud Volumes ONTAP systems to NetApp Console. You might do this if you deployed a new system.
Before you begin
You must know the password for the Cloud Volumes ONTAP admin user account.
Steps
From the left navigation menu, select Storage > Management.
On the System page, click Add System.
Select the cloud provider in which the system resides.
Choose the type of Cloud Volumes ONTAP system to add.
Click the link to discover an existing system.
On the Region page, select a region. You can see the systems that are running in the selected region.
Cloud Volumes ONTAP systems are represented as instances on this page. From the list, you can select only those instances that are registered with the current account.  -
On the Credentials page, enter the password for the Cloud Volumes ONTAP admin user, and then select Go.
Result
The Console adds the Cloud Volumes ONTAP systems to the Systems page.
